NTE QUICKCross, encuentra la equivalencia NTE – ECG
Mas reemplazos agregados a NTE:
RECTIFIERS:
NTE576-6
Rectifier - Silicon, 600V, 5A, Super Fast, trr = 35nS, DO-201AD Case
http://www.nteinc.com/specs/500to599/pdf/nte576.pdf
VARISTORS:
NTE605A
This was a previously discontinued NTE device.
Varistor - Temperature Compensating Diode, IF=100mA, VR=6V, DO-35 Case
http://www.nteinc.com/specs/600to699/pdf/nte605a.pdf
TRANSISTORS:
NTE2521
Transistor - NPN, Silicon, 250V, IC=300mA, Video Output for HDTV, TO-126ML Case
http://www.nteinc.com/specs/2500to2599/pdf/nte2521.pdf
NTE2695
Transistor - PNP, Silicon, 100V, IC=4A, Low Power Audio Amplifier, TO-126 Case
http://www.nteinc.com/specs/2600to2699/pdf/nte2695.pdf
NTE2696
Transistor - NPN, Silicon, 120V, IC=100mA, hFE=200-700, Low Noise Audio Amplifier, TO-92 Case
http://www.nteinc.com/specs/2600to2699/pdf/nte2696.pdf
MOSFETS:
NTE2948
Power MOSFET - N-Channel, 400V, ID=1A, Relay & Motor Driver, TO-251 Case
http://www.nteinc.com/specs/2900to2999/pdf/nte2948.pdf
NTE2949
Power MOSFET - N-Channel, 650V, ID=20.7A, RDS(on)=0.19 Ohm, TO-220 Full Pack Case
http://www.nteinc.com/specs/2900to2999/pdf/nte2949.pdf
INFRARED EMITTING DIODES:
NTE30130
Infrared Emitting Diode - 8mm, Water Clear Lens, 940nm, 150mw, Remote Control/Night Vision Applications
http://www.nteinc.com/specs/30100to30199/pdf/nte30130.pdf
NTE30131
Infrared Emitting Diode - 10mm, Water Clear Lens, 940nm, 150mw, Remote Control/Night Vision Applications
http://www.nteinc.com/specs/30100to30199/pdf/nte30131.pdf
NTE30132
Infrared Emitting Diode - 1.9mm, Water Clear Lens, 940nm, 130mw, Use with NTE30133
http://www.nteinc.com/specs/30100to30199/pdf/nte30132.pdf
PHOTOTRANSISTORS:
NTE30133
Infrared PhotoTransistor - 1.9mm, Water Clear Lens, 940nm, Silicon, VCEO=30V, Use with NTE30132
http://www.nteinc.com/specs/30100to30199/pdf/nte30133.pdf
Buenos días, resulta que entre mis cosas que yo tenía guardardas, encontré mi libro de NTE y ECG, creo que la última versión es la v15 impresa en papel.
Se me habia ocurrido, hacer un programa similar de forma que yo al buscar componente, me salte el resultado y me muestre las imágenes. Si, ya hay uno así y si, ya se puede usar haciendo lo mismo. Pero el instalador solo contiene las respuestas y links a los PDFs...
¿Alguien recuerda este programa? Así es, lo compartían por completo, pesaba más de 100mb y contenía toda la info Offline.
Con el auge de la tecnología y la Internet más accesible, dejaron de publicarlo offline y solo envían los resultados a PDF.
A mi se me ocurrió escanear todo el libro, si, lo desarmé hoja por hoja con los más de 900 hojas que trae... la mitad, si lo recuerdan, era el resultado del código NTE o bien ECG del componente original y la otra mitad, son los pinouts y diagramas de los mismos componentes NTE resultantes de la misma búsqueda.
A mi se me ocurrió escanear todo el libro, pasarlo a OCR y la segunda parte, razón de esta publicación, es ver si alguien me orienta a hacerlo portable con búsqueda...
Se me ocurría hacerlo en MySQL (MariaDB) almacenando las imágenes, los datos... para portarlo online, LAN, En un Hosting y compartirlo al mundo...
Se me ocurría hacerlo en Microsoft Office ACCESS para Windows y que todo estudiante tenga su copia a mano.
También se me ocurrió que pueda ser actualizable...
Bien, puedo seguir dos caminos
1. Bajar todos los PDFs y adjuntarlos a la búsqueda y solo poner un marco lector de PDF
2. Compartir mis hojas escaneadas poniendo los datos y las imágenes.
¿Ideas? estoy abierta a sugerencias.
¿Por qué lo hago? porque es una de mis metas de pequeña, hacer uno, quiero finalizar un proyecto que desde hace muchas lunas, yo tenía en mente. No importa que tan complicado o tedioso pueda parecer, es algo que me nace terminar...
Estoy abierta a sugerencias.
Tengo ya el libro escaneado y pesa demasiado más de 700MB, puesto que cada hoja tiene resolución de 100 DPI, está en escala de grises, con el OCR (reconocimiento de texto) en inglés.
Saludos cordiales.
