Hacer código compatible y legible.
Hola:
He probado este código de AVR de Atmel, por supusto que sirve para el compilador Arduino IDE 1.6.
Código:
// Timer and Counter example
// Author: Nick Gammon
// Date: 17th January 2012
// Input: Pin D5
// these are checked for in the main program
volatile unsigned long timerCounts;
volatile boolean counterReady;
// internal to counting routine
unsigned long overflowCount;
unsigned int timerTicks;
unsigned int timerPeriod;
void startCounting (unsigned int ms)
  counterReady = false;         // time not up yet
  timerPeriod = ms;             // how many 1 mS counts to do
  timerTicks = 0;               // reset interrupt counter
  overflowCount = 0;            // no overflows yet
  // reset Timer 1 and Timer 2
  TCCR1A = 0;
  TCCR1B = 0;
  TCCR2A = 0;
  TCCR2B = 0;
  // Timer 1 - counts events on pin D5
  TIMSK1 = bit (TOIE1);   // interrupt on Timer 1 overflow
  // Timer 2 - gives us our 1 mS counting interval
  // 16 MHz clock (62.5 nS per tick) - prescaled by 128
  //  counter increments every 8 µS.
  // So we count 125 of them, giving exactly 1000 µS (1 mS)
  TCCR2A = bit (WGM21) ;   // CTC mode
  OCR2A  = 124;            // count up to 125  (zero relative!!!!)
  // Timer 2 - interrupt on match (ie. every 1 mS)
  TIMSK2 = bit (OCIE2A);   // enable Timer2 Interrupt
  TCNT1 = 0;      // Both counters to zero
  TCNT2 = 0;
  // Reset prescalers
  GTCCR = bit (PSRASY);        // reset prescaler now
  // start Timer 2
  TCCR2B =  bit (CS20) | bit (CS22) ;  // prescaler of 128
  // start Timer 1
  // External clock source on T1 pin (D5). Clock on rising edge.
  TCCR1B =  bit (CS10) | bit (CS11) | bit (CS12);
  }  // end of startCounting
ISR (TIMER1_OVF_vect)
  ++overflowCount;               // count number of Counter1 overflows
  }  // end of TIMER1_OVF_vect
//  Timer2 Interrupt Service is invoked by hardware Timer 2 every 1ms = 1000 Hz
//  16Mhz / 128 / 125 = 1000 Hz
ISR (TIMER2_COMPA_vect)
  // grab counter value before it changes any more
  unsigned int timer1CounterValue;
  timer1CounterValue = TCNT1;  // see datasheet, page 117 (accessing 16-bit registers)
  unsigned long overflowCopy = overflowCount;
  // see if we have reached timing period
  if (++timerTicks < timerPeriod)
    return;  // not yet
  // if just missed an overflow
  if ((TIFR1 & bit (TOV1)) && timer1CounterValue < 256)
    overflowCopy++;
  // end of gate time, measurement ready
  TCCR1A = 0;    // stop timer 1
  TCCR1B = 0;
  TCCR2A = 0;    // stop timer 2
  TCCR2B = 0;
  TIMSK1 = 0;    // disable Timer1 Interrupt
  TIMSK2 = 0;    // disable Timer2 Interrupt
  // calculate total count
  timerCounts = (overflowCopy << 16) + timer1CounterValue;  // each overflow is 65536 more
  counterReady = true;              // set global flag for end count period
  }  // end of TIMER2_COMPA_vect
void setup ()
  Serial.begin(115200);
  Serial.println("Frequency Counter");
  } // end of setup
void loop ()
  // stop Timer 0 interrupts from throwing the count out
  byte oldTCCR0A = TCCR0A;
  byte oldTCCR0B = TCCR0B;
  TCCR0A = 0;    // stop timer 0
  TCCR0B = 0;
  startCounting (500);  // how many mS to count for
  while (!counterReady)
     { }  // loop until count over
  // adjust counts by counting interval to give frequency in Hz
  float frq = (timerCounts *  1000.0) / timerPeriod;
  Serial.print ("Frequency: ");
  Serial.print ((unsigned long) frq);
  Serial.println (" Hz.");
  // restart timer 0
  TCCR0A = oldTCCR0A;
  TCCR0B = oldTCCR0B;
  // let serial stuff finish
  delay(200);
  }   // end of loop
Está hecho en C nativo del AVR y en mi caso quiero pasarlo a C de Arduino que es más sencillo. ¿Alguien tiene idea?
Lo que hace leer todo el rato que frecuencia hay en el pin 5 y mostrarlo en el serial.
Y cual es el problema????
Hasta donde puedo analizar, todo el código es C ANSI salvo la declaración de la ISR.
Analizá como se declara una ISR en el C de Arduino y no deberían haber mas cambios.
O mejor aún aún, pasa el código por el compilador del Arduino y posteá los errores que genera...
No genera error.
BUENISIMO!!!!
El problema que usa cosas que en el Arduino no está como ,
TIMSK1,
TCCR1A y cosas así.
Y... deben ser registros del Atmel... pero el Arduino tambien tiene uno de esos chips, así que tendrás que buscar como se llaman en Arduino esos registros - si es que existen en esa plataforma - y cambiarle el nombre a esas variables.
Si no existen esos registros.... pues que vas a tener que modificar el programa
