Hola:
Cada vez más veo que a pesar de que los puertos series y paralelo se usan más sobre todas aquellas personas que están aprendiendo a controlar sea con Visual Basic, Visual C#, Visual C++, etc...
Me gustaría saber si alguien tiene experiencia en el tema de USB. Lo bueno que Microchip tiene los controladores par hacerlo más fácil.
Lo puedes ver aquí en los primeros enlaces.
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1410
Saludo.
		Código:
	;                            Software License Agreement
; The software supplied herewith by Microchip Technology Incorporated (the "Company")
; for its PICmicro(r) Microcontroller is intended and supplied to you, the Company's
; customer, for use solely and exclusively on Microchip PICmicro Microcontroller
; products.
; The software is owned by the Company and/or its supplier, and is protected under
; applicable copyright laws. All rights are reserved. Any use in violation of the
; foregoing restrictions may subject the user to criminal sanctions under applicable
; laws, as well as to civil liability for the breach of the terms and conditions of
; this license.
; THIS SOFTWARE IS PROVIDED IN AN "AS IS" CONDITION. NO WARRANTIES, WHETHER EXPRESS,
; IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED WARRANTIES OF
; MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE
; COMPANY SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR
; CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
;	filename:	DESCRIPT.ASM
; This file contains a set of descriptors for a standard mouse.
;	Author:			Dan Butler and Reston Condit
;	Company:		Microchip Technology Inc
;	Revision:		1.25
;	Date:			23 April 2002
;	Assembled using:	MPASM 2.80
;	include files:
;		P16C765.inc	Rev 1.00
;		usb_defs.inc	Rev 1.10
#include <p16C765.inc>
#include "usb_defs.inc"
USBBANK	code
	global	Config_desc_index
	global	Report_desc_index
	global	Descriptions
	global	string_index
	global	DeviceDescriptor
	global	ReportDescriptor
	global	ReportDescriptorLen
	global	String0
	global	String0_end
	global	StringDescriptions
	global	HID_Descriptor
	extern	EP0_start
	extern	temp		; temp var used in get config index
	extern	temp2 		; another temp, in bank2
; Given a configuration descriptor index, returns the beginning address
; of the descriptor within the descriptions table
Config_desc_index
	movwf	temp
	movlw	HIGH CDI_start
	movwf	PCLATH
	movlw	low CDI_start
	addwf	temp,w
	btfsc	STATUS,C
	incf	PCLATH,f
	movwf	PCL
CDI_start			; this table calculates the offsets for each
	retlw	low  Config1	; configuration descriptor from the beginning
	retlw	high Config1	; of the table
	; more configurations can be added here
	; retlw   low Config2
	; retlw   high Config2
	; etc....
; Given a report descriptor index, returns the beginning address
Report_desc_index
	movwf	temp
	movlw	HIGH RDI_start
	movwf	PCLATH
	movlw	low RDI_start
	addwf	temp,w
	btfsc	STATUS,C
	incf	PCLATH,f
	movwf	PCL
RDI_start		; this table calculates the offsets for each report
	retlw	low  ReportDescriptorLen  ; descriptor from the beginning
	retlw	high ReportDescriptorLen  ; of the table, effectively
	; more reports can be added here
	; retlw   low  ReportDescriptorLen2
	; retlw   high ReportDescriptorLen2
	; etc....
; This table is polled by the host immediately after USB Reset has been released.
; This table defines the maximum packet size EP0 can take.
; See section 9.6.1 of the Rev 1.0 USB specification.
; These fields are application DEPENDENT. Modify these to meet
; your specifications.
; the offset is passed in P0 and P1 (P0 is low order byte).
Descriptions
	banksel	EP0_start
	movf	EP0_start+1,w
	movwf	PCLATH
	movf	EP0_start,w
	movwf	PCL
DeviceDescriptor
StartDevDescr
	retlw	0x12		; bLengthLength of this descriptor
	retlw	0x01		; bDescType This is a DEVICE descriptor
	retlw	0x10		; bcdUSBUSB revision 1.10 (low byte)
	retlw	0x01		; high byte
	retlw	0x00		; bDeviceClasszero means each interface operates independently
	retlw	0x00		; bDeviceSubClass
	retlw	0x00		; bDeviceProtocol
	retlw	0x08		; bMaxPacketSize0 - inited in UsbInit()
	retlw	08		; idVendor - 0x04D8 is Microchip Vendor ID
	retlw	0x04		; high order byte
	retlw	0x00		; idProduct
	retlw	0x00
	retlw	0x41		; bcdDevice
	retlw	0x04
	retlw	0x01		; iManufacturer
	retlw	0x02		; iProduct
	retlw	0x00		; iSerialNumber - 3
	retlw	NUM_CONFIGURATIONS	; bNumConfigurations
; This table is retrieved by the host after the address has been set.
; This table defines the configurations available for the device.
; See section 9.6.2 of the Rev 1.0 USB specification (page 184).
; Modify these to meet your specifications.
Config1
	retlw	0x09		; bLengthLength of this descriptor
	retlw	0x02		; bDescType2 = CONFIGURATION
	retlw	EndConfig1 - Config1
	retlw	0x00
	retlw	0x01		; bNumInterfacesNumber of interfaces
	retlw	0x01		; bConfigValueConfiguration Value
	retlw	0x04		; iConfigString Index for this config = #01
	retlw	0xA0		; bmAttributesattributes - bus powered
	retlw	0x32		; MaxPowerself-powered draws 0 mA from the bus.
Interface1
	retlw	0x09		; length of descriptor
	retlw	INTERFACE
	retlw	0x00		; number of interface, 0 based array
	retlw	0x00		; alternate setting
	retlw	0x01		; number of endpoints used in this interface
	retlw	0x03		; interface class - assigned by the USB
	retlw	0x01		; boot device
	retlw	0x02		; interface protocol - mouse
	retlw	0x05		; index to string descriptor that describes this interface
HID_Descriptor
	retlw	0x09		; descriptor size (9 bytes)
	retlw	0x21		; descriptor type (HID)
	retlw	0x00
	retlw	0x01		; HID class release number (1.00)
	retlw	0x00		; Localized country code (none)
	retlw	0x01		; # of HID class descriptor to follow (1)
	retlw	0x22		; Report descriptor type (HID)
	retlw	(end_ReportDescriptor - ReportDescriptor)
	retlw	0x00
Endpoint1
	retlw	0x07		; length of descriptor
	retlw	ENDPOINT
	retlw	0x81		; EP1, In
	retlw	0x03		; Interrupt
	retlw	0x04		; max packet size (4 bytes) low order byte
	retlw	0x00		; max packet size (4 bytes) high order byte
	retlw	0x0A		; polling interval (10ms)
EndConfig1
ReportDescriptorLen
	retlw	low (end_ReportDescriptor-ReportDescriptor)
ReportDescriptor
	retlw	0x05
	retlw	0x01		; usage page (generic desktop)
	retlw	0x09
	retlw	0x02		; usage (mouse)
	retlw	0xA1
	retlw	0x01		; collection (application)
	retlw	0x09
	retlw	0x01		;usage (pointer)
	retlw	0xA1
	retlw	0x00		;collection (linked)
	retlw	0x05
	retlw	0x09		; usage page (buttons)
	retlw	0x19
	retlw	0x01		; usage minimum (1)
	retlw	0x29
	retlw	0x03		; usage maximum (3)
	retlw	0x15
	retlw	0x00		; logical minimum (0)
	retlw	0x25
	retlw	0x01		; logical maximum (1)
	retlw	0x95
	retlw	0x03		; report count (3)
	retlw	0x75
	retlw	0x01		; report size (1)
	retlw	0x81
	retlw	0x02		; input (3 button bits)
	retlw	0x95
	retlw	0x01		; report count (1)
	retlw	0x75
	retlw	0x05		; report size (5)
	retlw	0x81
	retlw	0x01		; input (constant 5 bit padding)
	retlw	0x05
	retlw	0x09
	retlw	0x30		; usage (X)
	retlw	0x09
	retlw	0x31		; usage (Y)
	retlw	0x15
	retlw	0x81		; logical minimum (-127)
	retlw	0x25
	retlw	0x7F		; logical maximum (127)
	retlw	0x75
	retlw	0x08		; report size (8)
	retlw	0x95
	retlw	0x03		; report count (2)
	retlw	0x81
	retlw	0x06		; input (2 position bytes X & Y)
	retlw	0xC0		; end collection
StringDescriptions
	banksel	EP0_start
	movf	EP0_start+1,w
	movwf	PCLATH
	movf	EP0_start,w
	movwf	PCL
string_index	; langid in W reg, string offset in EP0_start
	movwf	temp
	bcf 	STATUS,C
	rlf 	temp, f
	pagesel	langid_index
	call	langid_index
	movwf	temp2
	incf	temp, f
	call	langid_index
	movwf	temp
	movf	temp, w
	movwf	PCLATH
	movf	temp2,w
	addwf	EP0_start+1,w
	btfsc	STATUS,C
	incf	PCLATH, f
	movwf	PCL
langid_index
	movlw	high langids
	movwf	PCLATH
	movlw	low langids
	addwf	temp, w
	btfsc	STATUS,C
	incf	PCLATH,f
	movwf	PCL
langids
	retlw	low lang_1
	retlw	high lang_1
	retlw	low lang_2	; string indexes of different languages
	retlw	high lang_2
lang_1	; english
	retlw	low  String0	; LangIDs
	retlw	high String0
	retlw	low  String1_l1
	retlw	high String1_l1
	retlw	low  String2_l1
	retlw	high String2_l1
	retlw	low  String3_l1
	retlw	high String3_l1
	retlw	low  String4_l1
	retlw	high String4_l1
	retlw	low  String5_l1
	retlw	high String5_l1
	retlw	low  String6_l1
	retlw	high String6_l1
lang_2
	retlw	low  String0	; also point to LangID
	retlw	high String0
	retlw	low  String1_l2
	retlw	high String1_l2
	retlw	low  String2_l2
	retlw	high String2_l2
	retlw	low  String3_l2
	retlw	high String3_l2
	retlw	low  String4_l2
	retlw	high String4_l2
	retlw	low  String5_l2
	retlw	high String5_l2
String0
	retlw	low (String1_l1 - String0)	; length of string
	retlw	0x03		; descriptor type 3?
	retlw	0x09		; language ID (as defined by MS 0x0409)
	retlw	0x04
	retlw	0x04		; some other language ID for testing
	retlw	0x08
String0_end
String1_l1
	retlw	String2_l1-String1_l1	; length of string
	retlw	0x03		; string descriptor type 3
	retlw	'M'
	retlw	0x00
	retlw	'i'
	retlw	0x00
	retlw	'c'
	retlw	0x00
	retlw	'r'
	retlw	0x00
	retlw	'o'
	retlw	0x00
	retlw	'c'
	retlw	0x00
	retlw	'h'
	retlw	0x00
	retlw	'i'
	retlw	0x00
	retlw	'p'
	retlw	0x00
String2_l1
	retlw	String3_l1-String2_l1
	retlw	0x03
	retlw	'P'
	retlw	0x00
	retlw	'i'
	retlw	0x00
	retlw	'c'
	retlw	0x00
	retlw	'1'
	retlw	0x00
	retlw	'6'
	retlw	0x00
	retlw	'C'
	retlw	0x00
	retlw	'7'
	retlw	0x00
	retlw	'4'
	retlw	0x00
	retlw	'5'
	retlw	0x00
	retlw	'/'
	retlw	0x00
	retlw	'7'
	retlw	0x00
	retlw	'6'
	retlw	0x00
	retlw	'5'
	retlw	0x00
	retlw	' '
	retlw	0x00
	retlw	'U'
	retlw	0x00
	retlw	'S'
	retlw	0x00
	retlw	'B'
	retlw	0x00
	retlw	' '
	retlw	0x00
	retlw	'M'
	retlw	0x00
	retlw	'o'
	retlw	0x00
	retlw	'u'
	retlw	0x00
	retlw	's'
	retlw	0x00
	retlw	'e'
	retlw	0x00
String3_l1
	retlw	String4_l1-String3_l1
	retlw	0x03
	retlw	'V'
	retlw	0x00
	retlw	'1'
	retlw	0x00
	retlw	'.'
	retlw	0x00
	retlw	'1'
	retlw	0x00
	retlw	'1'
	retlw	0x00
String4_l1
	retlw	String5_l1-String4_l1
	retlw	0x03
	retlw	'C'
	retlw	0x00
	retlw	'f'
	retlw	0x00
	retlw	'g'
	retlw	0x00
	retlw	'1'
	retlw	0x00
String5_l1
	retlw	String6_l1-String5_l1
	retlw	0x03
	retlw	'E'
	retlw	0x00
	retlw	'P'
	retlw	0x00
	retlw	'1'
	retlw	0x00
	retlw	'0'
	retlw	0x00
	retlw	'I'
	retlw	0x00
	retlw	'n'
	retlw	0x00
String6_l1
String1_l2	; lang 2, chinese. String can be totally different than english
	retlw	String2_l2-String1_l2	; length of string
	retlw	'M'
	retlw	0x00
	retlw	'i'
	retlw	0x00
	retlw	'c'
	retlw	0x00
	retlw	'r'
	retlw	0x00
	retlw	'o'
	retlw	0x00
	retlw	'c'
	retlw	0x00
	retlw	'h'
	retlw	0x00
	retlw	'i'
	retlw	0x00
	retlw	'p'
	retlw	0x00
String2_l2
	retlw	String3_l2-String2_l2
	retlw	0x03
	retlw	'P'
	retlw	0x00
	retlw	'i'
	retlw	0x00
	retlw	'c'
	retlw	0x00
	retlw	'1'
	retlw	0x00
	retlw	'6'
	retlw	0x00
	retlw	'C'
	retlw	0x00
	retlw	'7'
	retlw	0x00
	retlw	'4'
	retlw	0x00
	retlw	'5'
	retlw	0x00
	retlw	'/'
	retlw	0x00
	retlw	'7'
	retlw	0x00
	retlw	'6'
	retlw	0x00
	retlw	'5'
	retlw	0x00
	retlw	' '
	retlw	0x00
	retlw	'U'
	retlw	0x00
	retlw	'S'
	retlw	0x00
	retlw	'B'
	retlw	0x00
	retlw	' '
	retlw	0x00
	retlw	'M'
	retlw	0x00
	retlw	'o'
	retlw	0x00
	retlw	'u'
	retlw	0x00
	retlw	's'
	retlw	0x00
	retlw	'e'
	retlw	0x00
String3_l2
	retlw	String4_l2-String3_l2
	retlw	0x03
	retlw	'V'
	retlw	0x00
	retlw	'1'
	retlw	0x00
	retlw	'.'
	retlw	0x00
	retlw	'1'
	retlw	0x00
	retlw	'1'
	retlw	0x00
String4_l2
	retlw	String5_l2-String4_l2
	retlw	0x03
	retlw	'C'
	retlw	0x00
	retlw	'f'
	retlw	0x00
	retlw	'g'
	retlw	0x00
	retlw	'1'
	retlw	0x00
String5_l2
	retlw	String6_l2-String5_l2
	retlw	0x03
	retlw	'E'
	retlw	0x00
	retlw	'P'
	retlw	0x00
	retlw	'1'
	retlw	0x00
	retlw	'0'
	retlw	0x00
	retlw	'I'
	retlw	0x00
	retlw	'n'
	retlw	0x00
String6_l2
	endLo puedes ver aquí en los primeros enlaces.
Saludo.
