Para conseguir el contador de décadas, se recuerda que la entrada de reloj CKB debe estar conectada a la
salida QA. Para conectar los dos contadores se debe llevar la salida QD de uno de ellos a la entrada CKA del
otro.
Gracias por la ayuda!!!
**** 06/28/10 10:25:01 ******* PSpice 16.3.0 (June 2009) ****** ID# 0 ********
** Profile: "SCHEMATIC1-TPN4" [ I:\TPN4\tpn4-potencia-pspicefiles\schematic1\tpn4.sim ]
**** CIRCUIT DESCRIPTION
** Creating circuit file "TPN4.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Profile Libraries :
.INC "I:\TPN4\tpn4-potencia-pspicefiles\schematic1\TPN4\TPN4_profile.inc"
* Local Libraries :
**** INCLUDING TPN4_profile.inc ****
.STMLIB ".\TPN4.stl"
**** RESUMING TPN4.cir ****
.STMLIB "../../../tpn4-potencia-pspicefiles/tpn4-potencia.stl"
* From [PSPICE NETLIST] section of C:\Cadence\SPB_16.3\tools\PSpice\PSpice.ini file:
.lib "nom.lib"
*Analysis directives:
.TRAN 0 60ms 0
.PROBE V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
.INC "..\SCHEMATIC1.net"
**** INCLUDING SCHEMATIC1.net ****
* source TPN4-POTENCIA
V_Van N19470 0 STIMULUS=Van
X_X1 N19470 N14903 N19523 MCR729-9
I_I1 0 N14903 STIMULUS=Ig1
X_X2 N19705 N21351 N19632 MCR729-9
X_X3 N19657 N21133 N19523 MCR729-9
X_X4 N19705 N21551 N19470 MCR729-9
X_X5 N19632 N21216 N19523 MCR729-9
X_X6 N19705 N21448 N19657 MCR729-9
V_Vbn N19657 0 STIMULUS=Vbn
V_Vcn N19632 0 STIMULUS=Vcn
I_I2 0 N21351 STIMULUS=Ig2
I_I3 0 N21133 STIMULUS=Ig3
I_I4 0 N21551 STIMULUS=Ig4
I_I5 0 N21216 STIMULUS=Ig5
I_I6 0 N21448 STIMULUS=Ig6
R_R1 N32494 N19523 1 TC=0,0
L_L1 N32494 N19705 10mH
.END
* J:\TPN4\TPN4-Potencia-PSpiceFiles\SCHEMATIC1\TPN4\TPN4.stl written on Wed Jun 23 17:51:22 2010
* by Stimulus Editor -- Serial Number: 1920102210 -- Version 16.3.0
;!Stimulus Get
;! Ig1 Analog Ig2 Analog Ig3 Analog Ig4 Analog Ig5 Analog Ig6 Analog
;!Ok
;!Plot Axis_Settings
;!Xrange 0s 32ms
;!Yrange 0 1
;!AutoUniverse
;!XminRes 1ns
;!YminRes 1n
;!Ok
.STIMULUS Ig1 PULSE( 0 1A 12.5ms 1u 1u 500u 3.3333m )
.STIMULUS Ig2 PULSE( 0 1A 15.8ms 1u 1u 500u 3.333m )
.STIMULUS Ig3 PULSE( 0 1A 19.1m 1u 1u 500u 3.3333m )
.STIMULUS Ig4 PULSE( 0 1A 21.9m 1u 1u 500u 3.3333m )
.STIMULUS Ig5 PULSE( 0 1A 12.5m 1u 1u 500u 3.3333m )
.STIMULUS Ig6 PULSE( 0 1A 12.5ms 1u 1u 500u 3.3333m )
**** Diode MODEL PARAMETERS
X_X1.X1.Dgk X_X1.X1.Dseries X_X1.X1.Delay X_X1.X1.Dkarev
IS 100.000000E-18 10.000000E-15 1.000000E-12 100.000000E-12
RS 5 .01 .01
CJO 50.000000E-12 5.000000E-12 5.000000E-12
X_X1.X1.Dakfwd X_X1.X1.Dbreak X_X2.X1.Dgk X_X2.X1.Dseries
IS 40.000000E-12 10.000000E-15 100.000000E-18 10.000000E-15
BV 770
IBV 100.000000E-09
RS .5 5
CJO 5.000000E-12 5.000000E-12 50.000000E-12
X_X2.X1.Delay X_X2.X1.Dkarev X_X2.X1.Dakfwd X_X2.X1.Dbreak
IS 1.000000E-12 100.000000E-12 40.000000E-12 10.000000E-15
BV 770
IBV 100.000000E-09
RS .01 .01 .5
CJO 5.000000E-12 5.000000E-12 5.000000E-12 5.000000E-12
X_X3.X1.Dgk X_X3.X1.Dseries X_X3.X1.Delay X_X3.X1.Dkarev
RS 5 .01 .01
X_X3.X1.Dakfwd X_X3.X1.Dbreak X_X4.X1.Dgk X_X4.X1.Dseries
BV 770
IBV 100.000000E-09
RS .5 5
X_X4.X1.Delay X_X4.X1.Dkarev X_X4.X1.Dakfwd X_X4.X1.Dbreak
BV 770
IBV 100.000000E-09
RS .01 .01 .5
X_X5.X1.Dgk X_X5.X1.Dseries X_X5.X1.Delay X_X5.X1.Dkarev
RS 5 .01 .01
X_X5.X1.Dakfwd X_X5.X1.Dbreak X_X6.X1.Dgk X_X6.X1.Dseries
BV 770
IBV 100.000000E-09
RS .5 5
X_X6.X1.Delay X_X6.X1.Dkarev X_X6.X1.Dakfwd X_X6.X1.Dbreak
BV 770
IBV 100.000000E-09
RS .01 .01 .5
**** Voltage Controlled Switch MODEL PARAMETERS
X_X1.X1.Vswitch X_X2.X1.Vswitch X_X3.X1.Vswitch X_X4.X1.Vswitch
RON .38 .38 .38 .38
ROFF 12.564100E+06 12.564100E+06 12.564100E+06 12.564100E+06
VON 5 5 5 5
VOFF 1.5 1.5 1.5 1.5
X_X5.X1.Vswitch X_X6.X1.Vswitch
RON .38 .38
VON 5 5
VOFF 1.5 1.5
**** INITIAL TRANSIENT SOLUTION TEMPERATURE = 27.000 DEG C
NODE VOLTAGE NODE VOLTAGE NODE VOLTAGE NODE VOLTAGE
(N14903)-943.0E-12 (N19470) 0.0000 (N19523)-943.0E-12 (N19632) 269.3300
(N19657) -269.3300 (N19705) 943.0E-12 (N21133)-943.0E-12 (N21216)-943.0E-12
(N21351) 269.3300 (N21448) -269.3300 (N21551) 0.0000 (N32494) 943.0E-12
(X_X1.X1.Itot) 1.366E-18 (X_X1.X1.prod) 1.288E-27
(X_X2.X1.Itot) 0.0000 (X_X2.X1.prod) 0.0000
(X_X3.X1.Itot) 0.0000 (X_X3.X1.prod) 0.0000
(X_X4.X1.Itot) 1.366E-18 (X_X4.X1.prod) 1.289E-27
(X_X5.X1.Itot) 21.41E-06 (X_X5.X1.prod) .0058
(X_X6.X1.Itot) 21.41E-06 (X_X6.X1.prod) .0058
(X_X1.X1.dlay1) 2.914E-27 (X_X1.X1.dlay2)-76.84E-27
(X_X1.X1.dvdt0) 943.0E-12 (X_X1.X1.dvdt1)-943.0E-12
(X_X1.X1.dvdt2)-943.0E-12 (X_X1.X1.gate1)-943.0E-12
(X_X1.X1.gate2)-943.0E-12 (X_X1.X1.gate4) 0.0000
(X_X2.X1.dlay1) 2.950E-27 (X_X2.X1.dlay2)-77.76E-27
(X_X2.X1.dvdt0) 0.0000 (X_X2.X1.dvdt1) 269.3300
(X_X2.X1.dvdt2) 269.3300 (X_X2.X1.gate1) 269.3300
(X_X2.X1.gate2) 269.3300 (X_X2.X1.gate4) 0.0000
(X_X3.X1.dlay1) 2.914E-27 (X_X3.X1.dlay2)-76.84E-27
(X_X3.X1.dvdt0) 0.0000 (X_X3.X1.dvdt1)-943.0E-12
(X_X3.X1.dvdt2)-943.0E-12 (X_X3.X1.gate1)-943.0E-12
(X_X3.X1.gate2)-943.0E-12 (X_X3.X1.gate4) 0.0000
(X_X4.X1.dlay1) 2.950E-27 (X_X4.X1.dlay2)-77.76E-27
(X_X4.X1.dvdt0) 943.0E-12 (X_X4.X1.dvdt1) 0.0000
(X_X4.X1.dvdt2) 0.0000 (X_X4.X1.gate1) 0.0000
(X_X4.X1.gate2) 0.0000 (X_X4.X1.gate4) 0.0000
(X_X5.X1.dlay1) 2.914E-27 (X_X5.X1.dlay2)-76.84E-27
(X_X5.X1.dvdt0) 269.3300 (X_X5.X1.dvdt1)-943.0E-12
(X_X5.X1.dvdt2)-943.0E-12 (X_X5.X1.gate1)-943.0E-12
(X_X5.X1.gate2)-943.0E-12 (X_X5.X1.gate4) 0.0000
(X_X6.X1.dlay1) 2.914E-27 (X_X6.X1.dlay2)-76.84E-27
(X_X6.X1.dvdt0) 269.3300 (X_X6.X1.dvdt1) -269.3300
(X_X6.X1.dvdt2) -269.3300 (X_X6.X1.gate1) -269.3300
(X_X6.X1.gate2) -269.3300 (X_X6.X1.gate4) 0.0000
(X_X1.X1.anode0)-60.07E-12 (X_X1.X1.anode2)-943.0E-12
(X_X1.X1.break1)-471.5E-12 (X_X1.X1.contot) 0.0000
(X_X2.X1.anode0) 269.0200 (X_X2.X1.anode2) 269.3300
(X_X2.X1.break1) 269.0700 (X_X2.X1.contot) 0.0000
(X_X3.X1.anode0) -.3175 (X_X3.X1.anode2)-943.0E-12
(X_X3.X1.break1) -.2638 (X_X3.X1.contot) 0.0000
(X_X4.X1.anode0) 883.0E-12 (X_X4.X1.anode2) 0.0000
(X_X4.X1.break1) 471.5E-12 (X_X4.X1.contot) 0.0000
(X_X5.X1.anode0) .3412 (X_X5.X1.anode2)-943.0E-12
(X_X5.X1.break1) 269.0700 (X_X5.X1.contot) 0.0000
(X_X6.X1.anode0) -268.9900 (X_X6.X1.anode2) -269.3300
(X_X6.X1.break1) -.2638 (X_X6.X1.contot) 0.0000
(X_X1.X1.condvdt) 0.0000 (X_X1.X1.congate) 0.0000
(X_X1.X1.conmain) 0.0000 (X_X1.X1.control) 476.5E-24
(X_X2.X1.condvdt) 0.0000 (X_X2.X1.congate) 0.0000
(X_X2.X1.conmain) 0.0000 (X_X2.X1.control)-373.2E-24
(X_X3.X1.condvdt) 0.0000 (X_X3.X1.congate) 0.0000
(X_X3.X1.conmain) 0.0000 (X_X3.X1.control) 476.5E-24
(X_X4.X1.condvdt) 0.0000 (X_X4.X1.congate) 0.0000
(X_X4.X1.conmain) 0.0000 (X_X4.X1.control)-373.2E-24
(X_X5.X1.condvdt) 0.0000 (X_X5.X1.congate) 0.0000
(X_X5.X1.conmain) 0.0000 (X_X5.X1.control) 476.5E-24
(X_X6.X1.condvdt) 0.0000 (X_X6.X1.congate) 0.0000
(X_X6.X1.conmain) 0.0000 (X_X6.X1.control) 476.5E-24
VOLTAGE SOURCE CURRENTS
NAME CURRENT
V_Van 2.390E-22
V_Vbn 4.282E-05
V_Vcn -4.282E-05
X_X1.X1.VIak 1.366E-18
X_X1.X1.VdVdt 5.796E-20
X_X1.X1.VIgf 9.430E-22
X_X2.X1.VIak -4.032E-11
X_X2.X1.VdVdt 0.000E+00
X_X2.X1.VIgf -2.693E-10
X_X3.X1.VIak -4.032E-11
X_X3.X1.VdVdt 0.000E+00
X_X3.X1.VIgf 9.430E-22
X_X4.X1.VIak 1.366E-18
X_X4.X1.VdVdt 0.000E+00
X_X4.X1.VIgf 0.000E+00
X_X5.X1.VIak 2.141E-05
X_X5.X1.VdVdt 0.000E+00
X_X5.X1.VIgf 9.430E-22
X_X6.X1.VIak 2.141E-05
X_X6.X1.VdVdt 0.000E+00
X_X6.X1.VIgf 2.693E-10
TOTAL POWER DISSIPATION 2.31E-02 WATTS
Reducing minimum delta to make the circuit converge.
ERROR -- Convergence problem in transient analysis at Time = .026
Time step = 158.7E-21, minimum allowable step size = 1.000E-18
These supply currents failed to converge:
I(X_X1.X1.Emon) = -3.815uA \ -2.163uA
I(X_X3.X1.Emon) = -1.907uA \ -2.295uA
I(X_X4.X1.Emon) = 0A \ -2.427uA
I(X_X5.X1.Emon) = -1.907uA \ -2.295uA
I(X_X1.X1.VdVdt) = 2.193uA \ 2.163uA
I(X_X1.X1.VIgf) = 1.511uA \ -208.57pA
I(X_X3.X1.VIak) = 238.42nA \ -2.990nA
I(X_X4.X1.VIak) = -357.63nA \ -648.19nA
I(X_X4.X1.VIgf) = 0A \ -305.59pA
I(X_X5.X1.VIak) = 119.21nA \ 10.96nA
I(X_X5.X1.VIgf) = -20.44nA \ -208.57pA
I(X_X6.X1.VIgf) = -953.67nA \ 87.31pA
These devices failed to converge:
X_X1.X1.Dton X_X1.X1.Dtoff X_X1.X1.Dbreak X_X2.X1.Dbreak X_X3.X1.Dak1
X_X3.X1.Dton X_X3.X1.Dtoff X_X3.X1.Dbreak X_X4.X1.Dak1 X_X4.X1.Dton
X_X4.X1.Dtoff X_X4.X1.Dbreak X_X5.X1.Dak1 X_X5.X1.Dton X_X5.X1.Dtoff
X_X5.X1.Dbreak X_X6.X1.Dton X_X6.X1.Dtoff X_X6.X1.Dbreak
Last node voltages tried were:
(N14903) 205.5800 (N19470) 301.2500 (N19523) 205.5800 (N19632) -217.5400
(N19657) -83.7040 (N19705) -83.1180 (N21133) 226.1100 (N21216) 205.5800
(N21351) -211.7300 (N21448) -83.7040 (N21551) 301.2500 (N32494) -45.1730
(X_X1.X1.Itot) 249.7500 (X_X1.X1.prod) 10.0000
(X_X2.X1.Itot) 250.6800 (X_X2.X1.prod) 10.0000
(X_X3.X1.Itot) .0050 (X_X3.X1.prod) 0.0000
(X_X4.X1.Itot) 0.0000 (X_X4.X1.prod) 0.0000
(X_X5.X1.Itot) 119.1E-09 (X_X5.X1.prod) 0.0000
(X_X6.X1.Itot) .0816 (X_X6.X1.prod) .0478
(X_X1.X1.dlay1) 10.0000 (X_X1.X1.dlay2) 10.0000
(X_X1.X1.dvdt0) 95.6680 (X_X1.X1.dvdt1) 205.5800
(X_X1.X1.dvdt2) 205.5800 (X_X1.X1.gate1) 205.5800
(X_X1.X1.gate2) 205.5800 (X_X1.X1.gate4) 0.0000
(X_X2.X1.dlay1) 5.2903 (X_X2.X1.dlay2) 10.5780
(X_X2.X1.dvdt0) 134.4200 (X_X2.X1.dvdt1) -290.2700
(X_X2.X1.dvdt2) -217.5400 (X_X2.X1.gate1) -215.5200
(X_X2.X1.gate2) -217.5400 (X_X2.X1.gate4) 10.0000
(X_X3.X1.dlay1)-9.550E-09 (X_X3.X1.dlay2) 24.85E-06
(X_X3.X1.dvdt0) 0.0000 (X_X3.X1.dvdt1) 205.5800
(X_X3.X1.dvdt2) 205.5800 (X_X3.X1.gate1) 211.1100
(X_X3.X1.gate2) 205.5800 (X_X3.X1.gate4) 10.0000
(X_X4.X1.dlay1)-14.07E-09 (X_X4.X1.dlay2) 37.16E-06
(X_X4.X1.dvdt0) 0.0000 (X_X4.X1.dvdt1) 301.2500
(X_X4.X1.dvdt2) 301.2500 (X_X4.X1.gate1) 301.2500
(X_X4.X1.gate2) 301.2500 (X_X4.X1.gate4) 0.0000
(X_X5.X1.dlay1)-25.64E-09 (X_X5.X1.dlay2) 69.99E-06
(X_X5.X1.dvdt0) 0.0000 (X_X5.X1.dvdt1) 205.5800
(X_X5.X1.dvdt2) 205.5800 (X_X5.X1.gate1) 205.5800
(X_X5.X1.gate2) 205.5800 (X_X5.X1.gate4) 0.0000
(X_X6.X1.dlay1) 10.0000 (X_X6.X1.dlay2) 10.0000
(X_X6.X1.dvdt0) .5862 (X_X6.X1.dvdt1) -156.4700
(X_X6.X1.dvdt2) -83.7040 (X_X6.X1.gate1) -83.7040
(X_X6.X1.gate2) -83.7040 (X_X6.X1.gate4) 0.0000
(X_X1.X1.anode0) 206.3400 (X_X1.X1.anode2) 205.5800
(X_X1.X1.break1) 982.2000 (X_X1.X1.contot) 10.0000
(X_X2.X1.anode0) -216.7800 (X_X2.X1.anode2) -217.5400
(X_X2.X1.break1) 372.9400 (X_X2.X1.contot) 10.0000
(X_X3.X1.anode0) 205.2600 (X_X3.X1.anode2) 205.5800
(X_X3.X1.break1) 364.3600 (X_X3.X1.contot) 0.0000
(X_X4.X1.anode0) 300.9200 (X_X4.X1.anode2) 301.2500
(X_X4.X1.break1) 358.8100 (X_X4.X1.contot) 0.0000
(X_X5.X1.anode0) 205.2500 (X_X5.X1.anode2) 205.5800
(X_X5.X1.break1) 379.3600 (X_X5.X1.contot) 0.0000
(X_X6.X1.anode0) -83.1480 (X_X6.X1.anode2) -83.7040
(X_X6.X1.break1) 388.8200 (X_X6.X1.contot) 10.0000
(X_X1.X1.conmain) 10.0000 (X_X1.X1.control) 9.7896
(X_X2.X1.condvdt) 0.0000 (X_X2.X1.congate) 10.0000
(X_X2.X1.conmain) 10.0000 (X_X2.X1.control) 4.7092
(X_X3.X1.conmain) 0.0000 (X_X3.X1.control) .1825
(X_X4.X1.conmain) 0.0000 (X_X4.X1.control) .1929
(X_X5.X1.conmain) 0.0000 (X_X5.X1.control) .2093
(X_X6.X1.conmain) 10.0000 (X_X6.X1.control) 9.8072
**** Interrupt ****
