Soft tipo skipe para red local
hay algun soft tipo skipe para red local
con texto, video, autologin
simple, bonito
que funcione en una red local sin internet:confused:
estuve buscando y solo encontre programas antiguos y descontinuados
http://www.cdmessenger.com/downloads/
http://squiggle.codeplex.com/releases/view/79013
estuve mirando y al parecer todos esos necesitan conexion a internt
o se ve con muchas opciones e iconos
lo ideal seria algo como telefonia ip sin servidor
con pocos botones y facil de usar
Can TeamViewer be used within a local network (LAN) only?
You can establish Remote control sessions on your local network directly by using IP addresses or computer names. By default this feature is deactivated because software firewalls may open an acceptance dialog when configured this way.
To activate the LAN mode in TeamViewer full version and Host module:
In the menu click on Extras and then on Options
On the General tab activate Accept incoming LAN connections
When selecting accept exclusively it will display the IP-address of the computer in the ID-field.
A connection can now be established using the IP-address or alternatively using the host name.
