//// EX_USB_BOOTLOADER.C ////
//// This program is an example stand alone USB bootloader. It uses ////
//// the communication device class (CDC) that creates a virtual COM ////
//// port on your PC. The bootloader contains it's own set of USB ////
//// and bootloader code in low memory, the high memory will contain ////
//// the application (and if you are developing a USB application, ////
//// this will hold it's own USB code). ////
//// This program must be loaded into a target chip using a device ////
//// programmer. Afterwards this program may be used to load new ////
//// versions of the application program. There is a specific ////
//// protocol used by the bootloader, SIOW.EXE uses this protocol ////
//// if you use the 'Download Software' option. ////
//// Compiling this program gives you a HEX file of just the loader. ////
//// To load the application you have two choices: a.) use the loader ////
//// to load the application, or b.) merge the application HEX and ////
//// loader HEX into one production HEX. The #import() CCS command ////
//// will help you perfrom the latter. Be aware that if you do the ////
//// former the PIC will get it's configuration bit settings (fuses) ////
//// from the loader and not the application (this bootloader does ////
//// not change the configuration bits) ////
//// To create an application that is compatible with this loader ////
//// simply #include usb_bootlaoder.h into your application. This ////
//// loader does support interrupts in your application. ////
//// This bootloader is designed to detect pin A4 low on reset (this ////
//// is the push-button on the CCS USB Development kit). If A4 is ////
//// low it starts the USB CDC stack and checks for bootload ////
//// information over USB. Otherwise the application program is ////
//// started. ////
//// This is a port of ex_bootloader.c, which is a serial bootloader. ////
//// Since CDC makes it easy to port legacy applications, the ////
//// previous example makes the bulk of this code. ////
//// This example will work with the PCH compiler. The ////
//// following conditional compilation lines are used to include a ////
//// valid device for each compiler. Change the device, clock and ////
//// RS232 pins for your hardware if needed. ////
//// This file is part of CCS's PIC USB driver code. See USB.H ////
//// for more documentation and a list of examples. ////
//// VERSION HISTORY ////
//// March 5th, 2009: ////
//// Cleanup for Wizard. ////
//// PIC24 Initial release. ////
//// (C) Copyright 1996,2009 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS ////
//// C compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, ////
//// reproduction or distribution is permitted without written ////
//// permission. Derivative programs created using this software ////
//// in object code form are not restricted in any way. ////
//set to 1 to use a PIC's internal USB Peripheral
//set to 0 to use a National USBN960x peripheral
#define __USB_PIC_PERIF__ 1
#if !defined(__PCH__)
#error This bootloader written for PIC18
#endif
#if __USB_PIC_PERIF__
#INCLUDE <18f2550.h>
#fuses HSPLL,NOMCLR,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN,NOPBADEN
#USE delay (clock=20mhz)
//configure a 20MHz crystal to operate at 48MHz, for 4550
/* #include <18F4550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
//configure a 8MHz crystal to operate at 48MHz, for 67j50
//#include <18F67J50.h>
//#fuses H4_SW,NOXINST,NOWDT,NOSTVREN,NOFCMEN,NOIESO,NOPROTECT,NODEBUG,PLL2,NOCPUDIV
#use delay(clock=48000000)*/
#else //use the National USBN960x peripheral
#include <18F452.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP
#use delay(clock=20000000)
#endif //endif check to see which peripheral to use
// If you are using a USB connection sense pin, define it here. If you are
// not using connection sense, comment out this line. Without connection
// sense you will not know if the device gets disconnected.
// (connection sense should look like this:
// 100k
// VBUS-----+----/\/\/\/\/\----- (I/O PIN ON PIC)
// +----/\/\/\/\/\-----GND
// 100k
// (where VBUS is pin1 of the USB connector)
///only ccs's 18F4550 development kit has this pin
#if __USB_PIC_PERIF__ && defined(__PCH__)
#define USB_CON_SENSE_PIN PIN_B2
#endif
#define LOADER_ISR 0x28
#build(interrupt=LOADER_ISR)
Configure, then load the bootloader definitions
#define _bootloader
#include <usb_bootloader.h>
// Includes all USB code and interrupts, as well as the CDC API
#include <usb_cdc.h>
Goto the interrupt vector of the application.
#org 0x08,0x17
void high_isr(void)
if (bit_test(g_InBootloader,0))
#ASM
goto LOADER_ISR
#ENDASM
else
#ASM
goto APPLICATION_ISR
#ENDASM
#org 0x18,0x27
void low_isr(void)
#ASM
goto LOADER_ISR+0x10
#ENDASM
else
#ASM
goto APPLICATION_ISR+0x10
#ENDASM
#define ROM_BLOCK_INVALID -1
int32 rom_block_start = ROM_BLOCK_INVALID;
#define EEPROM_ERASE_SIZE getenv("FLASH_ERASE_SIZE")
int8 rom_block[EEPROM_ERASE_SIZE];
// see rom_w() documentation. performs the flushing
void rom_w_flush(void)
if (rom_block_start != ROM_BLOCK_INVALID)
erase_program_eeprom(rom_block_start); //erase entire block
write_program_memory(rom_block_start, rom_block, sizeof(rom_block)); //write modified block
// see rom_w() documentation. performs the writing
void rom_w_block(int32 location, char *src, int16 size)
int32 block_start;
int16 i,num;
block_start = location & (~((int32)EEPROM_ERASE_SIZE-1));
i = location - block_start;
while (size)
if (block_start != rom_block_start)
rom_w_flush();
rom_block_start = block_start;
read_program_memory(block_start, rom_block, sizeof(rom_block)); //read entire block to ram buffer
if (size>(EEPROM_ERASE_SIZE-i)) {num=EEPROM_ERASE_SIZE-i;} else {num=size;}
memcpy(&rom_block[i], src, num); //modify ram buffer
src += num;
block_start += EEPROM_ERASE_SIZE;
i = 0;
size -= num;
// Write to Flash ROM.
// location - flash program memory address
// src - pointer to data to write
// size - number of bytes to write to flash
// Here is the sequence of events:
// 1.) Goes to the beginning of the first erase block for this address
// 2.) Reads n records to ram, where n is the PIC's flash erase size
// 3.) Erases block in flash
// 4.) Modifies block in RAM
// 5.) Writes changed block back to FLASH. Writes in chunks defined by PIC's flash write size
// 6.) Goes back to step1 if there is still more data to be written
void rom_w(int32 location, char *src, int16 size)
rom_w_block(location, src, size);
rom_w_flush();
#define BUFFER_LEN_LOD 64
#define ACKLOD 0x06
#define XON 0x11
#define XOFF 0x13
// Convert two hex characters to a int8
unsigned int8 atoi_b16(char *s)
char c;
unsigned int8 result = 0;
int i;
for (i=0; i<2; i++,s++)
c = *s;
if (c >= 'A')
result = 16*result + c - 'A' + 10;
else
result = 16*result + c - '0';
return(result);
void load_program(void)
int1 do_ACKLOD, done=FALSE;
int8 checksum, line_type;
int16 l_addr,h_addr=0;
int8 to;
int32 addr;
int8 dataidx, i, count;
int8 data[32];
int buffidx;
char buffer[BUFFER_LEN_LOD];
while (!done) // Loop until the entire program is downloaded
usb_task();
if (!usb_cdc_kbhit())
continue;
buffidx = 0; // Read into the buffer until 0x0D ('\r') is received or the buffer is full
to = 250; //250 milliseconds
do
delay_ms(1);
to--;
if (!to)
break;
else
to = 250;
i = usb_cdc_getc();
buffer[buffidx++] = i;
} while ( (i != 0x0D) && (i != 0x0A) && (buffidx <= BUFFER_LEN_LOD) );
if (!to)
continue;
usb_cdc_putc(XOFF); // Suspend sender
do_ACKLOD = TRUE;
// Only process data blocks that start with ':'
if (buffer[0] == ':')
count = atoi_b16 (&buffer[1]); // Get the number of bytes from the buffer
// Get the lower 16 bits of address
l_addr = make16(atoi_b16(&buffer[3]),atoi_b16(&buffer[5]));
line_type = atoi_b16 (&buffer[7]);
addr = make32(h_addr,l_addr);
checksum = 0; // Sum the bytes to find the check sum value
for (i=1; i<(buffidx-3); i+=2)
checksum += atoi_b16 (&buffer[i]);
checksum = 0xFF - checksum + 1;
if (checksum != atoi_b16 (&buffer[buffidx-3]))
do_ACKLOD = FALSE;
else
// If the line type is 1, then data is done being sent
if (line_type == 1)
done = TRUE;
else if (line_type == 4)
h_addr = make16(atoi_b16(&buffer[9]), atoi_b16(&buffer[11]));
else if ((line_type == 0) && (addr >= (int32)APPLICATION_START) && (addr < ((int32)APPLICATION_END)))
// Loops through all of the data and stores it in data
// The last 2 bytes are the check sum, hence buffidx-3
for (i = 9,dataidx=0; i < buffidx-3; i += 2)
data[dataidx++]=atoi_b16(&buffer[i]);
rom_w_block(addr, data, count);
if (do_ACKLOD)
usb_cdc_putc (ACKLOD);
usb_cdc_putc(XON);
rom_w_flush();
usb_cdc_putc(XON);
delay_ms(2000); //give time for packet to flush
reset_cpu();
void main(void)
#if (defined(__USB_87J50__) && (getenv("FUSE_SET:H4_SW")))
#byte OSCTUNE = 0xF9B
#bit PLLEN=OSCTUNE.6
PLLEN = TRUE;
delay_ms(250);
#endif
//we use PIN_A4 as an event to determine if we should start the USB CDC
//bootloader. if it is not low (button is not pressed) then goto the
//application, else if is low (button is pressed) then do the bootloader.
if(!input(PIN_a0))
g_InBootloader = TRUE;
usb_cdc_init();
usb_init();
while(!usb_enumerated());
load_program();
g_InBootloader = FALSE;
#ASM
goto APPLICATION_START
#ENDASM
