[ 24.224]
X.Org X Server 1.16.1
Release Date: 2014-09-21
[ 24.225] X Protocol Version 11, Revision 0
[ 24.225] Build Operating System: openSUSE SUSE LINUX
[ 24.225] Current Operating System: Linux OpenSuse 3.16.7-35-desktop
[ 24.225] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.16.7-35-desktop root=UUID=a1ba422f-4a12-42fd-b38e-f49c742ee91b resume=/dev/disk/by-uuid/ca94ea87-dc1d-452b-9439-feb3e42b26c7 splash=silent quiet showopts
[ 24.225] Build Date: 08 February 2016 10:44:47AM
[ 24.225]
[ 24.225] Current version of pixman: 0.32.6
[ 24.225] Before reporting problems, check [url]http:
to make sure that you have the latest version.
[ 24.225] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 24.225] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Jul 8 20:14:29 2016
[ 24.225] (==) Using config file: "/etc/X11/xorg.conf"
[ 24.225] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 24.225] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 24.225] (==) ServerLayout "TwinLayout"
[ 24.225] (**) |-->Screen "aticonfig-Screen[0]-0" (0)
[ 24.225] (**) | |-->Monitor "aticonfig-Monitor[0]-0"
[ 24.225] (**) | |-->Device "aticonfig-Device[0]-0"
[ 24.225] (==) Automatically adding devices
[ 24.225] (==) Automatically enabling devices
[ 24.225] (==) Automatically adding GPU devices
[ 24.237] (WW) The directory "/usr/share/fonts/misc/sgi" does not exist.
[ 24.237] Entry deleted from font path.
[ 24.237] (==) FontPath set to:
/usr/share/fonts/misc:unscaled,
/usr/share/fonts/Type1/,
/usr/share/fonts/100dpi:unscaled,
/usr/share/fonts/75dpi:unscaled,
/usr/share/fonts/ghostscript/,
/usr/share/fonts/cyrillic:unscaled,
/usr/share/fonts/truetype/,
built-ins
[ 24.237] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 24.237] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 24.237] (II) Loader magic: 0x826f660
[ 24.237] (II) Module ABI versions:
[ 24.237] X.Org ANSI C Emulation: 0.4
[ 24.237] X.Org Video Driver: 18.0
[ 24.237] X.Org XInput driver : 21.0
[ 24.237] X.Org Server Extension : 8.0
[ 24.237] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 24.242] (--) PCI: (0:0:2:0) 8086:0412:1043:8534 rev 6, Mem @ 0xf7800000/4194304, 0xd0000000/268435456, I/O @ 0x0000f000/64
[ 24.242] (--) PCI:*(0:1:0:0) 1002:6810:174b:e271 rev 0, Mem @ 0xe0000000/268435456, 0xf7d00000/262144, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[ 24.242] (II) "glx" will be loaded by default.
[ 24.242] (II) LoadModule: "glx"
[ 24.271] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 24.271] (II) Module glx: vendor="Advanced Micro Devices, Inc."
[ 24.271] compiled for 6.9.0, module version = 1.0.0
[ 24.271] (II) LoadModule: "fglrx"
[ 24.271] (II) Loading /usr/lib/xorg/modules/drivers/fglrx_drv.so
[ 24.381] (II) Module fglrx: vendor="FireGL - AMD Technologies Inc."
[ 24.381] compiled for 1.4.99.906, module version = 15.20.3
[ 24.381] Module class: X.Org Video Driver
[ 24.385] (II) Loading sub module "fglrxdrm"
[ 24.385] (II) LoadModule: "fglrxdrm"
[ 24.385] (II) Loading /usr/lib/xorg/modules/linux/libfglrxdrm.so
[ 24.385] (II) Module fglrxdrm: vendor="FireGL - AMD Technologies Inc."
[ 24.385] compiled for 1.4.99.906, module version = 15.20.3
[ 24.385] (II) AMD Proprietary Linux Driver Version Identifier:15.20.3
[ 24.385] (II) AMD Proprietary Linux Driver Release Identifier: UNSUPPORTED-15.201.1151
[ 24.385] (II) AMD Proprietary Linux Driver Build Date: Sep 8 2015 15:06:34
[ 24.385] (++) using VT number 7
[ 24.385] (WW) Falling back to old probe method for fglrx
[ 24.408] (II) Loading PCS database from /etc/ati/amdpcsdb /etc/ati/amdpcsdb.default
[ 24.409] ukiDynamicMajor: found major device number 250
[ 24.409] ukiOpenByBusid: Searching for BusID PCI:1:0:0
[ 24.409] ukiOpenDevice: node name is /dev/ati/card0
[ 24.409] ukiOpenDevice: open result is 9, (OK)
[ 24.752] ukiOpenByBusid: ukiOpenMinor returns 9
[ 24.752] ukiOpenByBusid: ukiGetBusid reports PCI:1:0:0
[ 24.765] (--) Chipset Supported AMD Graphics Processor (0x6810) found
[ 24.765] (WW) fglrx: No matching Device section for instance (BusID PCI:0@1:0:1) found
[ 24.766] (II) fglrx(0): pEnt->device->identifier=0x890fbe8
[ 24.766] (II) fglrx(0): === [xdl_xs116_atiddxPreInit] === begin
[ 24.766] (II) fglrx(0): FB driver is enabled
[ 24.766] (II) Loading sub module "vgahw"
[ 24.766] (II) LoadModule: "vgahw"
[ 24.797] (II) Loading /usr/lib/xorg/modules/libvgahw.so
[ 24.797] (II) Module vgahw: vendor="X.Org Foundation"
[ 24.797] compiled for 1.16.1, module version = 0.1.0
[ 24.797] ABI class: X.Org Video Driver, version 18.0
[ 24.797] (**) fglrx(0): Depth 24, (--) framebuffer bpp 32
[ 24.797] (II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 24.797] (==) fglrx(0): Default visual is TrueColor
[ 24.797] (**) fglrx(0): Option "DPMS" "true"
[ 24.797] (==) fglrx(0): RGB weight 888
[ 24.797] (II) fglrx(0): Using 8 bits per RGB
[ 24.797] (==) fglrx(0): Buffer Tiling is ON
[ 24.797] (II) Loading sub module "fglrxdrm"
[ 24.797] (II) LoadModule: "fglrxdrm"
[ 24.797] (II) Loading /usr/lib/xorg/modules/linux/libfglrxdrm.so
[ 24.797] (II) Module fglrxdrm: vendor="FireGL - AMD Technologies Inc."
[ 24.797] compiled for 1.4.99.906, module version = 15.20.3
[ 24.798] ukiDynamicMajor: found major device number 250
[ 24.798] ukiOpenByBusid: Searching for BusID PCI:1:0:0
[ 24.798] ukiOpenDevice: node name is /dev/ati/card0
[ 24.798] ukiOpenDevice: open result is 11, (OK)
[ 24.798] ukiOpenByBusid: ukiOpenMinor returns 11
[ 24.798] ukiOpenByBusid: ukiGetBusid reports PCI:1:0:0
[ 24.798] (**) fglrx(0): NoAccel = NO
[ 24.799] (**) fglrx(0): AMD 2D Acceleration Architecture enabled
[ 24.799] (--) fglrx(0): Chipset: "AMD Radeon R9 200 Series" (Chipset = 0x6810)
[ 24.799] (--) fglrx(0): (PciSubVendor = 0x174b, PciSubDevice = 0xe271)
[ 24.799] (==) fglrx(0): board vendor info: third party graphics adapter - NOT original AMD
[ 24.799] (--) fglrx(0): Linear framebuffer (phys) at 0xe0000000
[ 24.799] (--) fglrx(0): MMIO registers at 0xf7d00000
[ 24.799] (--) fglrx(0): I/O port at 0x0000e000
[ 24.799] (==) fglrx(0): ROM-BIOS at 0x000c0000
[ 24.808] (II) fglrx(0): AC Adapter is used
[ 24.809] (II) fglrx(0): Primary V_BIOS segment is: 0xc000
[ 24.810] (II) Loading sub module "vbe"
[ 24.810] (II) LoadModule: "vbe"
[ 24.810] (II) Loading /usr/lib/xorg/modules/libvbe.so
[ 24.810] (II) Module vbe: vendor="X.Org Foundation"
[ 24.810] compiled for 1.16.1, module version = 1.1.0
[ 24.810] ABI class: X.Org Video Driver, version 18.0
[ 24.810] (II) fglrx(0): VESA BIOS detected
[ 24.810] (II) fglrx(0): VESA VBE Version 3.0
[ 24.810] (II) fglrx(0): VESA VBE Total Mem: 16384 kB
[ 24.810] (II) fglrx(0): VESA VBE OEM: AMD ATOMBIOS
[ 24.810] (II) fglrx(0): VESA VBE OEM Software Rev: 15.42
[ 24.810] (II) fglrx(0): VESA VBE OEM Vendor: (C) 1988-2010, Advanced Micro Devices, Inc.
[ 24.810] (II) fglrx(0): VESA VBE OEM Product: CURACAO
[ 24.810] (II) fglrx(0): VESA VBE OEM Product Rev: 01.00
[ 24.810] (II) fglrx(0): AMD Video BIOS revision 9 or later detected
[ 24.810] (--) fglrx(0): Video RAM: 2097152 kByte, Type: GDDR5
[ 24.810] (II) fglrx(0): PCIE card detected
[ 24.810] (--) fglrx(0): Using per-process page tables (PPPT) as GART.
[ 24.810] (WW) fglrx(0): board is an unknown third party board, chipset is supported
[ 24.810] (II) fglrx(0): [FB] MC range(MCFBBase = 0xf400000000, MCFBSize = 0x80000000)
[ 24.810] (II) fglrx(0): RandR 1.2 support is enabled!
[ 24.810] (II) fglrx(0): RandR 1.2 rotation support is enabled!
[ 24.810] (II) Loading sub module "fb"
[ 24.810] (II) LoadModule: "fb"
[ 24.810] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 24.810] (II) Module fb: vendor="X.Org Foundation"
[ 24.810] compiled for 1.16.1, module version = 1.0.0
[ 24.810] ABI class: X.Org ANSI C Emulation, version 0.4
[ 24.810] (II) fglrx(0): EDID Management option: EDID Management is enabled
[ 24.810] (II) Loading sub module "ddc"
[ 24.810] (II) LoadModule: "ddc"
[ 24.810] (II) Module "ddc" already built-in
[ 24.945] (II) fglrx(0): Output DFP1 using monitor section aticonfig-Monitor[0]-0
[ 24.945] (II) fglrx(0): Output DFP2 has no monitor section
[ 24.945] (II) fglrx(0): Output DFP3 has no monitor section
[ 24.945] (II) fglrx(0): Output DFP4 has no monitor section
[ 24.945] (II) fglrx(0): Output DFP5 has no monitor section
[ 24.945] (II) fglrx(0): Output DFP6 has no monitor section
[ 24.945] (II) fglrx(0): Output DFP7 has no monitor section
[ 24.945] (II) fglrx(0): Output CRT1 has no monitor section
[ 24.945] (II) Loading sub module "ddc"
[ 24.945] (II) LoadModule: "ddc"
[ 24.945] (II) Module "ddc" already built-in
[ 24.945] (II) fglrx(0): Connected Display0: DFP6
[ 24.945] (II) fglrx(0): Display0 EDID data ---------------------------
[ 24.945] (II) fglrx(0): Manufacturer: DEL Model: 4091 Serial
[ 24.945] (II) fglrx(0): Year: 2015 Week: 36
[ 24.945] (II) fglrx(0): EDID Version: 1.3
[ 24.945] (II) fglrx(0): Digital Display Input
[ 24.945] (II) fglrx(0): Max Image Size [cm]: horiz.: 53 vert.: 30
[ 24.945] (II) fglrx(0): Gamma: 2.20
[ 24.945] (II) fglrx(0): DPMS capabilities: StandBy Suspend Off
[ 24.945] (II) fglrx(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 24.945] (II) fglrx(0): Default color space is primary color space
[ 24.945] (II) fglrx(0): First detailed timing is preferred mode
[ 24.945] (II) fglrx(0): redX: 0.645 redY: 0.332 greenX: 0.315 greenY: 0.619
[ 24.945] (II) fglrx(0): blueX: 0.151 blueY: 0.065 whiteX: 0.313 whiteY: 0.329
[ 24.945] (II) fglrx(0): Supported established timings:
[ 24.945] (II) fglrx(0): 720x400@70Hz
[ 24.945] (II) fglrx(0): 640x480@60Hz
[ 24.945] (II) fglrx(0): 640x480@75Hz
[ 24.945] (II) fglrx(0): 800x600@60Hz
[ 24.945] (II) fglrx(0): 800x600@75Hz
[ 24.945] (II) fglrx(0): 1024x768@60Hz
[ 24.945] (II) fglrx(0): 1024x768@75Hz
[ 24.945] (II) fglrx(0): 1280x1024@75Hz
[ 24.945] (II) fglrx(0): Manufacturer's mask: 0
[ 24.945] (II) fglrx(0): Supported standard timings:
[ 24.945] (II) fglrx(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 24.945] (II) fglrx(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 24.945] (II) fglrx(0): #2: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 24.945] (II) fglrx(0): #3: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 24.945] (II) fglrx(0): Supported detailed timing:
[ 24.945] (II) fglrx(0): clock: 148.5 MHz Image Size: 531 x 299 mm
[ 24.945] (II) fglrx(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 24.945] (II) fglrx(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 24.945] (II) fglrx(0): Serial No: FF3N1594B77U
[ 24.945] (II) fglrx(0): Monitor name: DELL E2414H
[ 24.945] (II) fglrx(0): Ranges: V min: 56 V max: 76 Hz, H min: 30 H max: 83 kHz, PixClock max 175 MHz
[ 24.945] (II) fglrx(0): EDID (in hex):
[ 24.945] (II) fglrx(0): 00ffffffffffff0010ac914055373742
[ 24.945] (II) fglrx(0): 2419010380351e78ee0ef5a555509e26
[ 24.945] (II) fglrx(0): 105054a54b00714f8180a9c0d1c00101
[ 24.945] (II) fglrx(0): 010101010101023a801871382d40582c
[ 24.945] (II) fglrx(0): 4500132b2100001e000000ff00464633
[ 24.945] (II) fglrx(0): 4e31353934423737550a000000fc0044
[ 24.945] (II) fglrx(0): 454c4c204532343134480a20000000fd
[ 24.945] (II) fglrx(0): 00384c1e5311000a20202020202000d8
[ 24.945] (II) fglrx(0): End of Display0 EDID data --------------------
[ 24.945] (II) fglrx(0): Dynamic Surface Resizing Enabled
[ 24.945] (II) fglrx(0): EDID for output DFP1
[ 24.945] (II) fglrx(0): EDID for output DFP2
[ 24.945] (II) fglrx(0): EDID for output DFP3
[ 24.945] (II) fglrx(0): EDID for output DFP4
[ 24.945] (II) fglrx(0): EDID for output DFP5
[ 24.945] (II) fglrx(0): EDID for output DFP6
[ 24.945] (II) fglrx(0): Manufacturer: DEL Model: 4091 Serial#: 1110914901
[ 24.945] (II) fglrx(0): Printing probed modes for output DFP6
[ 24.945] (II) fglrx(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 24.945] (II) fglrx(0): Modeline "1680x1050"x60.0 148.50 1680 2008 2052 2200 1050 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 24.945] (II) fglrx(0): Modeline "1400x1050"x60.0 148.50 1400 2008 2052 2200 1050 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 24.945] (II) fglrx(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 24.945] (II) fglrx(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 24.945] (II) fglrx(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 24.945] (II) fglrx(0): Modeline "1440x900"x60.0 108.00 1440 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 24.945] (II) fglrx(0): Modeline "1280x960"x75.0 135.00 1280 1296 1440 1688 960 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 24.945] (II) fglrx(0): Modeline "1280x960"x60.0 108.00 1280 1328 1440 1688 960 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 24.945] (II) fglrx(0): Modeline "1152x864"x60.0 148.50 1152 2008 2052 2200 864 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 24.945] (II) fglrx(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 24.945] (II) fglrx(0): Modeline "1280x768"x75.0 135.00 1280 1296 1440 1688 768 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 24.945] (II) fglrx(0): Modeline "1280x768"x60.0 108.00 1280 1328 1440 1688 768 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 24.945] (II) fglrx(0): Modeline "1280x720"x75.0 135.00 1280 1296 1440 1688 720 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 24.945] (II) fglrx(0): Modeline "1280x720"x60.0 108.00 1280 1328 1440 1688 720 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 24.945] (II) fglrx(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 24.945] (II) fglrx(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 24.945] (II) fglrx(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 24.945] (II) fglrx(0): Modeline "800x600"x60.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 24.945] (II) fglrx(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 24.945] (II) fglrx(0): Modeline "640x480"x60.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 24.945] (II) fglrx(0): EDID for output DFP7
[ 24.945] (II) fglrx(0): EDID for output CRT1
[ 24.945] (II) fglrx(0): Output DFP1 disconnected
[ 24.945] (II) fglrx(0): Output DFP2 disconnected
[ 24.945] (II) fglrx(0): Output DFP3 disconnected
[ 24.945] (II) fglrx(0): Output DFP4 disconnected
[ 24.945] (II) fglrx(0): Output DFP5 disconnected
[ 24.945] (II) fglrx(0): Output DFP6 connected
[ 24.945] (II) fglrx(0): Output DFP7 disconnected
[ 24.945] (II) fglrx(0): Output CRT1 disconnected
[ 24.945] (II) fglrx(0): Using exact sizes for initial modes
[ 24.945] (II) fglrx(0): Output DFP6 using initial mode 1920x1080
[ 24.945] (II) fglrx(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 24.945] (II) fglrx(0): DPI set to (96, 96)
[ 24.945] (II) fglrx(0): Eyefinity capable adapter detected.
[ 24.945] (II) fglrx(0): Adapter AMD Radeon R9 200 Series has 6 configurable heads and 1 displays connected.
[ 24.945] (==) fglrx(0): PseudoColor visuals disabled
[ 24.945] (II) Loading sub module "ramdac"
[ 24.945] (II) LoadModule: "ramdac"
[ 24.945] (II) Module "ramdac" already built-in
[ 24.945] (==) fglrx(0): NoDRI = NO
[ 24.945] (==) fglrx(0): Capabilities: 0x00000000
[ 24.945] (==) fglrx(0): CapabilitiesEx: 0x00000000
[ 24.945] (==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
[ 24.945] (==) fglrx(0): UseFastTLS=0
[ 24.945] (II) fglrx(0): Desktop Vsync is enabled.
[ 24.945] (II) fglrx(0): Shadow Primary option: ShadowPrimary is enabled
[ 24.945] (--) Depth 24 pixmap format is 32 bpp
[ 24.946] (II) fglrx(0): doing swlDriScreenInit
[ 24.946] (II) fglrx(0): swlDriScreenInit for fglrx driver
[ 24.946] ukiDynamicMajor: found major device number 250
[ 24.946] ukiOpenByBusid: Searching for BusID PCI:1:0:0
[ 24.946] ukiOpenDevice: node name is /dev/ati/card0
[ 24.946] ukiOpenDevice: open result is 12, (OK)
[ 24.946] ukiOpenByBusid: ukiOpenMinor returns 12
[ 24.946] ukiOpenByBusid: ukiGetBusid reports PCI:1:0:0
[ 24.946] (II) fglrx(0): [uki] DRM interface version 1.0
[ 24.946] (II) fglrx(0): [uki] created "fglrx" driver at busid "PCI:1:0:0"
[ 24.946] (II) fglrx(0): [uki] added 8192 byte SAREA at 0x2000
[ 24.946] (II) fglrx(0): [uki] mapped SAREA 0x2000 to 0xb7729000
[ 24.946] (II) fglrx(0): [uki] framebuffer handle = 0x3000
[ 24.946] (II) fglrx(0): [uki] added 1 reserved context for kernel
[ 24.946] (II) fglrx(0): swlDriScreenInit done
[ 24.946] (II) fglrx(0): Kernel Module Version Information:
[ 24.946] (II) fglrx(0): Name: fglrx
[ 24.946] (II) fglrx(0): Version: 15.20.3
[ 24.946] (II) fglrx(0): Date: Sep 8 2015
[ 24.946] (II) fglrx(0): Desc: AMD FireGL DRM kernel module
[ 24.946] (II) fglrx(0): Kernel Module version matches driver.
[ 24.946] (II) fglrx(0): Kernel Module Build Time Information:
[ 24.946] (II) fglrx(0): Build-Kernel UTS_RELEASE: 3.16.7-35-desktop
[ 24.946] (II) fglrx(0): Build-Kernel MODVERSIONS: yes
[ 24.946] (II) fglrx(0): Build-Kernel __SMP__: yes
[ 24.946] (II) fglrx(0): Build-Kernel PAGE_SIZE: 0x1000
[ 24.946] (II) fglrx(0): [uki] register handle = 0x00004000
[ 24.951] (II) fglrx(0): DRI initialization successfull
[ 24.951] (II) fglrx(0): FBADPhys: 0xf400000000 FBMappedSize: 0x010e0000
[ 24.951] (==) fglrx(0): Backing store enabled
[ 24.951] (**) fglrx(0): DPMS enabled
[ 24.951] (II) fglrx(0): Initialized in-driver Xinerama extension
[ 24.951] (**) fglrx(0): Textured Video is enabled.
[ 24.951] (II) LoadModule: "glesx"
[ 24.951] (II) Loading /usr/lib/xorg/modules/glesx.so
[ 25.067] (II) Module glesx: vendor="X.Org Foundation"
[ 25.067] compiled for 1.4.99.906, module version = 1.0.0
[ 25.067] (II) fglrx(0): GLESX enableFlags = 8784
[ 25.068] (II) fglrx(0): GLESX is enabled
[ 25.068] (II) LoadModule: "amdxmm"
[ 25.068] (II) Loading /usr/lib/xorg/modules/amdxmm.so
[ 25.068] (II) Module amdxmm: vendor="X.Org Foundation"
[ 25.068] compiled for 1.4.99.906, module version = 2.0.0
[ 25.089] (II) fglrx(0): UVD feature is enabled(II) fglrx(0):
[ 25.090] (II) fglrx(0): Enable composite support successfully
[ 25.090] (WW) fglrx(0): Option "Monitor-VGA1" is not used
[ 25.090] (WW) fglrx(0): Option "VendorName" is not used
[ 25.090] (WW) fglrx(0): Option "ModelName" is not used
[ 25.090] (WW) fglrx(0): Option "TwinView" is not used
[ 25.090] (II) fglrx(0): X context handle = 0x1
[ 25.090] (II) fglrx(0): [DRI] installation complete
[ 25.090] (==) fglrx(0): Silken mouse enabled
[ 25.090] (==) fglrx(0): Using HW cursor of display infrastructure!
[ 25.090] (II) fglrx(0): LPT is disabled by configure option
[ 25.090] (II) fglrx(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 25.404] (--) RandR disabled
[ 25.408] ukiDynamicMajor: found major device number 250
[ 25.408] ukiOpenByBusid: Searching for BusID PCI:1:0:0
[ 25.408] ukiOpenDevice: node name is /dev/ati/card0
[ 25.408] ukiOpenDevice: open result is 13, (OK)
[ 25.408] ukiOpenByBusid: ukiOpenMinor returns 13
[ 25.408] ukiOpenByBusid: ukiGetBusid reports PCI:1:0:0
[ 25.725] ukiDynamicMajor: found major device number 250
[ 25.725] ukiOpenDevice: node name is /dev/ati/card0
[ 25.725] ukiOpenDevice: open result is 14, (OK)
[ 25.725] ukiGetBusid returned 'PCI:1:0:0'
[ 25.725] ukiOpenDevice: node name is /dev/ati/card1
[ 25.725] ukiOpenDevice: open result is -1, (No such device)
[ 25.725] ukiOpenDevice: Open failed
[ 25.725] ukiOpenDevice: node name is /dev/ati/card2
[ 25.725] ukiOpenDevice: node name is /dev/ati/card3
[ 25.725] ukiOpenDevice: node name is /dev/ati/card4
[ 25.725] ukiOpenDevice: node name is /dev/ati/card5
[ 25.725] ukiOpenDevice: node name is /dev/ati/card6
[ 25.725] ukiOpenDevice: node name is /dev/ati/card7
[ 25.725] ukiOpenDevice: node name is /dev/ati/card8
[ 25.725] ukiOpenDevice: node name is /dev/ati/card9
[ 25.725] ukiOpenDevice: node name is /dev/ati/card10
[ 25.725] ukiOpenDevice: node name is /dev/ati/card11
[ 25.725] ukiOpenDevice: node name is /dev/ati/card12
[ 25.725] ukiOpenDevice: node name is /dev/ati/card13
[ 25.725] ukiOpenDevice: node name is /dev/ati/card14
[ 25.726] ukiOpenDevice: open result is -1, (No such device)
[ 25.726] ukiOpenDevice: Open failed
[ 25.726] ukiOpenDevice: node name is /dev/ati/card15
[ 25.726] ukiDynamicMajor: found major device number 250
[ 25.726] ukiOpenByBusid: Searching for BusID PCI:1:0:0
[ 25.726] ukiOpenDevice: node name is /dev/ati/card0
[ 25.726] ukiOpenDevice: open result is 14, (OK)
[ 25.726] ukiOpenByBusid: ukiOpenMinor returns 14
[ 25.726] ukiOpenByBusid: ukiGetBusid reports PCI:1:0:0
[ 25.741] (II) AIGLX: Loaded and initialized OpenGL driver(II) GLX: Initialized DRI GL provider for screen 0
[ 25.784] ukiDynamicMajor: found major device number 250
[ 25.784] ukiOpenDevice: node name is /dev/ati/card0
[ 25.784] ukiOpenDevice: open result is 15, (OK)
[ 25.784] ukiGetBusid returned 'PCI:1:0:0'
[ 25.784] ukiOpenDevice: node name is /dev/ati/card1
[ 25.784] ukiOpenDevice: open result is -1, (No such device)
[ 25.784] ukiOpenDevice: Open failed
[ 25.784] ukiOpenDevice: node name is /dev/ati/card2
[ 25.784] ukiOpenDevice: node name is /dev/ati/card3
[ 25.784] ukiOpenDevice: node name is /dev/ati/card4
[ 25.784] ukiOpenDevice: node name is /dev/ati/card5
[ 25.784] ukiOpenDevice: node name is /dev/ati/card6
[ 25.784] ukiOpenDevice: node name is /dev/ati/card7
[ 25.784] ukiOpenDevice: node name is /dev/ati/card8
[ 25.784] ukiOpenDevice: node name is /dev/ati/card9
[ 25.784] ukiOpenDevice: node name is /dev/ati/card10
[ 25.784] ukiOpenDevice: node name is /dev/ati/card11
[ 25.784] ukiOpenDevice: node name is /dev/ati/card12
[ 25.784] ukiOpenDevice: node name is /dev/ati/card13
[ 25.784] ukiOpenDevice: node name is /dev/ati/card14
[ 25.784] ukiOpenDevice: node name is /dev/ati/card15
[ 25.784] ukiOpenByBusid: Searching for BusID PCI:1:0:0
[ 25.784] ukiOpenByBusid: ukiOpenMinor returns 15
[ 25.784] ukiOpenByBusid: ukiGetBusid reports PCI:1:0:0
[ 25.838] (II) fglrx(0): OverDrive5 Detected!
[ 25.857] (II) fglrx(0): Desktop Vsync is enabled.
[ 25.857] (II) fglrx(0): TFD direct rotation is possible with 90/180/270 rotation
[ 25.857] (II) fglrx(0): Setting screen physical size to 507 x 285
[ 25.883] (II) config/udev: Adding input device Power Button (/dev/input/event5)
[ 25.883] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 25.883] (**) Power Button: Applying InputClass "system-keyboard"
[ 25.883] (II) LoadModule: "evdev"
[ 25.883] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 25.884] (II) Module evdev: vendor="X.Org Foundation"
[ 25.884] compiled for 1.16.1, module version = 2.9.0
[ 25.884] Module class: X.Org XInput Driver
[ 25.884] ABI class: X.Org XInput driver, version 21.0
[ 25.884] (II) Using input driver 'evdev' for 'Power Button'
[ 25.884] (**) Power Button: always reports core events
[ 25.884] (**) evdev: Power Button: Device: "/dev/input/event5"
[ 25.884] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 25.884] (--) evdev: Power Button: Found keys
[ 25.884] (II) evdev: Power Button: Configuring as keyboard
[ 25.884] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input6/event5"
[ 25.884] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 25.884] (**) Option "xkb_rules" "evdev"
[ 25.884] (**) Option "xkb_model" "pc105"
[ 25.884] (**) Option "xkb_layout" "es"
[ 25.884] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 25.895] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[ 25.895] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 25.895] (**) Video Bus: Applying InputClass "system-keyboard"
[ 25.895] (II) Using input driver 'evdev' for 'Video Bus'
[ 25.895] (**) Video Bus: always reports core events
[ 25.895] (**) evdev: Video Bus: Device: "/dev/input/event6"
[ 25.895] (--) evdev: Video Bus: Vendor 0 Product 0x6
[ 25.895] (--) evdev: Video Bus: Found keys
[ 25.895] (II) evdev: Video Bus: Configuring as keyboard
[ 25.895] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input7/event6"
[ 25.895] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 25.895] (**) Option "xkb_rules" "evdev"
[ 25.895] (**) Option "xkb_model" "pc105"
[ 25.895] (**) Option "xkb_layout" "es"
[ 25.895] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 25.895] (II) config/udev: Adding input device Power Button (/dev/input/event4)
[ 25.895] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 25.895] (**) Power Button: Applying InputClass "system-keyboard"
[ 25.895] (II) Using input driver 'evdev' for 'Power Button'
[ 25.895] (**) Power Button: always reports core events
[ 25.895] (**) evdev: Power Button: Device: "/dev/input/event4"
[ 25.895] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 25.895] (--) evdev: Power Button: Found keys
[ 25.895] (II) evdev: Power Button: Configuring as keyboard
[ 25.895] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input5/event4"
[ 25.895] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 25.895] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event10)
[ 25.895] (II) No input driver specified, ignoring this device.
[ 25.895] (II) This device may have been added with another device file.
[ 25.896] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=7 (/dev/input/event11)
[ 25.896] (II) No input driver specified, ignoring this device.
[ 25.896] (II) This device may have been added with another device file.
[ 25.896] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=8 (/dev/input/event12)
[ 25.896] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=9 (/dev/input/event13)
[ 25.896] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=10 (/dev/input/event14)
[ 25.896] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=11 (/dev/input/event15)
[ 25.896] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event9)
[ 25.896] (II) config/udev: Adding input device HID 073a:2230 (/dev/input/event2)
[ 25.896] (**) HID 073a:2230: Applying InputClass "evdev pointer catchall"
[ 25.896] (**) HID 073a:2230: Applying InputClass "evdev keyboard catchall"
[ 25.896] (**) HID 073a:2230: Applying InputClass "system-keyboard"
[ 25.896] (II) Using input driver 'evdev' for 'HID 073a:2230'
[ 25.896] (**) HID 073a:2230: always reports core events
[ 25.896] (**) evdev: HID 073a:2230: Device: "/dev/input/event2"
[ 25.896] (--) evdev: HID 073a:2230: Vendor 0x73a Product 0x2230
[ 25.896] (--) evdev: HID 073a:2230: Found 20 mouse buttons
[ 25.896] (--) evdev: HID 073a:2230: Found scroll wheel(s)
[ 25.896] (--) evdev: HID 073a:2230: Found relative axes
[ 25.896] (--) evdev: HID 073a:2230: Found x and y relative axes
[ 25.896] (--) evdev: HID 073a:2230: Found absolute axes
[ 25.896] (II) evdev: HID 073a:2230: Forcing absolute x/y axes to exist.
[ 25.896] (--) evdev: HID 073a:2230: Found keys
[ 25.896] (II) evdev: HID 073a:2230: Configuring as mouse
[ 25.896] (II) evdev: HID 073a:2230: Configuring as keyboard
[ 25.896] (II) evdev: HID 073a:2230: Adding scrollwheel support
[ 25.896] (**) evdev: HID 073a:2230: YAxisMapping: buttons 4 and 5
[ 25.897] (**) evdev: HID 073a:2230: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 25.897] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.0/0003:073A:2230.0001/input/input3/event2"
[ 25.897] (II) XINPUT: Adding extended input device "HID 073a:2230" (type: KEYBOARD, id 9)
[ 25.897] (**) Option "xkb_rules" "evdev"
[ 25.897] (**) Option "xkb_model" "pc105"
[ 25.897] (**) Option "xkb_layout" "es"
[ 25.897] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 25.897] (II) evdev: HID 073a:2230: initialized for relative axes.
[ 25.897] (WW) evdev: HID 073a:2230: ignoring absolute axes.
[ 25.897] (**) HID 073a:2230: (accel) keeping acceleration scheme 1
[ 25.897] (**) HID 073a:2230: (accel) acceleration profile 0
[ 25.897] (**) HID 073a:2230: (accel) acceleration factor: 2.000
[ 25.897] (**) HID 073a:2230: (accel) acceleration threshold: 4
[ 25.897] (II) config/udev: Adding input device HID 073a:2230 (/dev/input/js0)
[ 25.897] (**) HID 073a:2230: Applying InputClass "system-keyboard"
[ 25.897] (II) No input driver specified, ignoring this device.
[ 25.897] (II) This device may have been added with another device file.
[ 25.897] (II) config/udev: Adding input device HID 073a:2230 (/dev/input/mouse1)
[ 25.897] (II) config/udev: Adding input device Logitech Logitech RumblePad 2 USB (/dev/input/event3)
[ 25.897] (II) config/udev: Adding input device Logitech Logitech RumblePad 2 USB (/dev/input/js1)
[ 25.897] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event16)
[ 25.898] (II) No input driver specified, ignoring this device.
[ 25.898] (II) This device may have been added with another device file.
[ 25.898] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event17)
[ 25.898] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event18)
[ 25.898] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event19)
[ 25.898] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event20)
[ 25.898] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event8)
[ 25.898] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 25.898] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[ 25.898] (II) Using input driver 'evdev' for 'Eee PC WMI hotkeys'
[ 25.898] (**) Eee PC WMI hotkeys: always reports core events
[ 25.898] (**) evdev: Eee PC WMI hotkeys: Device: "/dev/input/event8"
[ 25.898] (--) evdev: Eee PC WMI hotkeys: Vendor 0 Product 0
[ 25.898] (--) evdev: Eee PC WMI hotkeys: Found keys
[ 25.898] (II) evdev: Eee PC WMI hotkeys: Configuring as keyboard
[ 25.898] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input9/event8"
[ 25.898] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 10)
[ 25.898] (**) Option "xkb_rules" "evdev"
[ 25.898] (**) Option "xkb_model" "pc105"
[ 25.898] (**) Option "xkb_layout" "es"
[ 25.898] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 25.898] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 25.898] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 25.898] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 25.898] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[ 25.898] (**) AT Translated Set 2 keyboard: always reports core events
[ 25.898] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event0"
[ 25.898] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[ 25.899] (--) evdev: AT Translated Set 2 keyboard: Found keys
[ 25.899] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[ 25.899] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[ 25.899] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 11)
[ 25.899] (**) Option "xkb_rules" "evdev"
[ 25.899] (**) Option "xkb_model" "pc105"
[ 25.899] (**) Option "xkb_layout" "es"
[ 25.899] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 25.899] (II) config/udev: Adding input device ImPS/2 Generic Wheel Mouse (/dev/input/event1)
[ 25.899] (**) ImPS/2 Generic Wheel Mouse: Applying InputClass "evdev pointer catchall"
[ 25.899] (II) Using input driver 'evdev' for 'ImPS/2 Generic Wheel Mouse'
[ 25.899] (**) ImPS/2 Generic Wheel Mouse: always reports core events
[ 25.899] (**) evdev: ImPS/2 Generic Wheel Mouse: Device: "/dev/input/event1"
[ 25.899] (--) evdev: ImPS/2 Generic Wheel Mouse: Vendor 0x2 Product 0x5
[ 25.899] (--) evdev: ImPS/2 Generic Wheel Mouse: Found 3 mouse buttons
[ 25.899] (--) evdev: ImPS/2 Generic Wheel Mouse: Found scroll wheel(s)
[ 25.899] (--) evdev: ImPS/2 Generic Wheel Mouse: Found relative axes
[ 25.899] (--) evdev: ImPS/2 Generic Wheel Mouse: Found x and y relative axes
[ 25.899] (II) evdev: ImPS/2 Generic Wheel Mouse: Configuring as mouse
[ 25.899] (II) evdev: ImPS/2 Generic Wheel Mouse: Adding scrollwheel support
[ 25.899] (**) evdev: ImPS/2 Generic Wheel Mouse: YAxisMapping: buttons 4 and 5
[ 25.899] (**) evdev: ImPS/2 Generic Wheel Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 25.899] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input2/event1"
[ 25.899] (II) XINPUT: Adding extended input device "ImPS/2 Generic Wheel Mouse" (type: MOUSE, id 12)
[ 25.899] (II) evdev: ImPS/2 Generic Wheel Mouse: initialized for relative axes.
[ 25.899] (**) ImPS/2 Generic Wheel Mouse: (accel) keeping acceleration scheme 1
[ 25.899] (**) ImPS/2 Generic Wheel Mouse: (accel) acceleration profile 0
[ 25.899] (**) ImPS/2 Generic Wheel Mouse: (accel) acceleration factor: 2.000
[ 25.899] (**) ImPS/2 Generic Wheel Mouse: (accel) acceleration threshold: 4
[ 25.899] (II) config/udev: Adding input device ImPS/2 Generic Wheel Mouse (/dev/input/mouse0)
[ 25.899] (II) No input driver specified, ignoring this device.
[ 25.899] (II) This device may have been added with another device file.
[ 25.899] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[ 25.924] (II) fglrx(0): Restoring Recent Mode via PCS is not supported in RANDR 1.2 capable environments
[ 31.252] (II) fglrx(0): EDID vendor "DEL", prod id 16529
[ 31.252] (II) fglrx(0): Using EDID range info for horizontal sync
[ 31.252] (II) fglrx(0): Using EDID range info for vertical refresh
[ 31.252] (II) fglrx(0): Printing DDC gathered Modelines:
[ 31.252] (II) fglrx(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 31.252] (II) fglrx(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 31.252] (II) fglrx(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 31.252] (II) fglrx(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 31.252] (II) fglrx(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 31.252] (II) fglrx(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 31.252] (II) fglrx(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 31.252] (II) fglrx(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 31.252] (II) fglrx(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 31.252] (II) fglrx(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 31.252] (II) fglrx(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 31.252] (II) fglrx(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 31.252] (II) fglrx(0): Modeline "1920x1080"x60.0 172.80 1920 2040 2248 2576 1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[ 32.037] (II) fglrx(0): EDID vendor "DEL", prod id 16529
[ 32.037] (II) fglrx(0): Using hsync ranges from config file
[ 32.037] (II) fglrx(0): Using vrefresh ranges from config file
[ 32.037] (II) fglrx(0): Printing DDC gathered Modelines:
[ 32.037] (II) fglrx(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 32.037] (II) fglrx(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 32.037] (II) fglrx(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 32.037] (II) fglrx(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 32.037] (II) fglrx(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 32.037] (II) fglrx(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 32.037] (II) fglrx(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 32.037] (II) fglrx(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 32.037] (II) fglrx(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 32.037] (II) fglrx(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 32.037] (II) fglrx(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 32.037] (II) fglrx(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 32.037] (II) fglrx(0): Modeline "1920x1080"x60.0 172.80 1920 2040 2248 2576 1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
