He configurado mi nodMCU ESP 8266 y cuando trato de conectarme con el código a 'Firebase' me sale el siguiente error.
Si alguien me podría explicar que pasa.
Gracias de antemano.
-- Error:
C:\Users\Contabilidad\Documents\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp: In member function 'virtual void FirebaseHttpClientEsp8266::begin(const string&)':
C:\Users\Contabilidad\Documents\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp:47:50: error: no matching function for call to 'begin(const char*, const char [60])'
47 | http_.begin(url.c_str(), kFirebaseFingerprint);
In file included from C:\Users\Contabilidad\Documents\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp:9:
C:\Users\Contabilidad\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:166:10: note: candidate: 'bool HTTPClient::begin(String, uint16_t, String)' (near match)
166 | bool begin(String host, uint16_t port, String uri = "/") __attribute__ ((error("obsolete API, use ::begin(WiFiClient, host, port, uri)")));
C:\Users\Contabilidad\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:166:10: note: conversion of argument 2 would be ill-formed:
C:\Users\Contabilidad\Documents\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp:47:30: error: invalid conversion from 'const char*' to 'uint16_t' {aka 'short unsigned int'} [-fpermissive]
| const char*
C:\Users\Contabilidad\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:167:10: note: candidate: 'bool HTTPClient::begin(String, const uint8_t*)' (near match)
167 | bool begin(String url, const uint8_t httpsFingerprint[20]) __attribute__ ((error("obsolete API, use ::begin(WiFiClientSecure, ...)")));
C:\Users\Contabilidad\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:167:10: note: conversion of argument 2 would be ill-formed:
C:\Users\Contabilidad\Documents\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp:47:30: error: invalid conversion from 'const char*' to 'const uint8_t*' {aka 'const unsigned char*'} [-fpermissive]
| const char*
C:\Users\Contabilidad\Documents\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp: In member function 'virtual void FirebaseHttpClientEsp8266::begin(const string&, const string&)':
C:\Users\Contabilidad\Documents\Arduino\libraries\firebase-arduino-master\src\FirebaseHttpClient_Esp8266.cpp:51:60: error: invalid conversion from 'const char*' to 'const uint8_t*' {aka 'const unsigned char*'} [-fpermissive]
51 | http_.begin(host.c_str(), kFirebasePort, path.c_str(), kFirebaseFingerprint);
| const char*
C:\Users\Contabilidad\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266HTTPClient\src/ESP8266HTTPClient.h:168:70: note: initializing argument 4 of 'bool HTTPClient::begin(String, uint16_t, String, const uint8_t*)'
168 | bool begin(String host, uint16_t port, String uri, const uint8_t httpsFingerprint[20]) __attribute__ ((error("obsolete API, use ::begin(WiFiClientSecure, ...)")));
Se encontraron varias bibliotecas para "ArduinoJson.h"
Usado: C:\Users\Contabilidad\Documents\Arduino\libraries\ArduinoJson
No usado: C:\Users\Contabilidad\Documents\Arduino\libraries\ArduinoJson-6.x
exit status 1
Error compilando para la tarjeta NodeMCU 1.0 (ESP-12E Module).
Este informe podría contener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
-- Error:
| const char*
| const char*
| const char*
exit status 1
