Proba con un cristal de 4MHz, a mí nunca me andan los lcd con mayor velocidad que esa.
entonces que puedo hacer... ya estoy arta... no encuentro el error... plis que alguien me ayude...
george.manson.69.
Recuerdas el favor que te pedi al respecto del pequeño publik .
del curso de mcu..
Me podrias colaborar..???
Gracias amigo..
hola george.manson quisiera saber como agregar esa libreria de keypath 4x4 a mi software ccs para asi trabajar mas facilmente podrias explicar el codigo de ejemplo que encontrastehola ingdenis1 encontre esta liberia de un teclado 4x4 en google...a ver si te sirve!
Código://///////////////////////////////////////////////////////////////////////// //// KBD_LIB.C by Redraven //// //// //// //// Derived from KBDD.C //// //// Generic keypad scan driver //// //// //// //// kbd_init() Must be called before any other function. //// //// //// //// c = kbd_getc(c) Will return a key value if pressed or /0 if not //// //// This function should be called frequently so as //// //// not to miss a key press. //// //// //// /////////////////////////////////////////////////////////////////////////// //// (C) Copyright 1996,1997 Custom Computer Services //// //// This source code may only be used by licensed users of the CCS C //// //// compiler. This source code may only be distributed to other //// //// licensed users of the CCS C compiler. No other use, reproduction //// //// or distribution is permitted without written permission. //// //// Derivative programs created using this software in object code //// //// form are not restricted in any way. //// //////////////////////////////////////////////////////////////////////////// ////////////////// The following defines the keypad layout on port D // Un-comment the following define to use port B #define use_portb_kbd TRUE // Make sure the port used has pull-up resistors (or the LCD) on // the column pins #if defined(__PCH__) #if defined use_portb_kbd #byte kbd = 0xF81 // This puts the entire structure #else #byte kbd = 0xF83 // This puts the entire structure #endif #else #if defined use_portb_kbd #byte kbd = 6 // on to port B (at address 6) #else #byte kbd = 8 // on to port D (at address 8) #endif #endif #if defined use_portb_kbd #define set_tris_kbd(x) set_tris_b(x) #else #define set_tris_kbd(x) set_tris_d(x) #endif //Keypad connection: (for example column 0 is B0) #define COL0 (1 << 0) // PIN_B0 #define COL1 (1 << 1) // PIN_B1 #define COL2 (1 << 2) // PIN_B2 #define COL3 (1 << 3) // PIN_B3 #define ROW0 (1 << 4) // PIN_B4 #define ROW1 (1 << 5) // PIN_B5 #define ROW2 (1 << 6) // PIN_B6 #define ROW3 (1 << 7) // PIN_B7 #define ALL_ROWS (ROW0|ROW1|ROW2|ROW3) #define ALL_PINS (ALL_ROWS|COL0|COL1|COL2|COL3) // Keypad layout: char const KEYS[4][4] = {{'1','2','3','A'}, {'4','5','6','B'}, {'7','8','9','C'}, {'*','0','#','D'}}; #define KBD_DEBOUNCE_FACTOR 33 // Set this number to apx n/333 where // n is the number of times you expect // to call kbd_getc each second void kbd_init() { } char kbd_getc( ) { static byte kbd_call_count; static short int kbd_down; static char last_key; static byte col; byte kchar; byte row; kchar='\0'; if(++kbd_call_count>KBD_DEBOUNCE_FACTOR) { switch (col) { case 0 : set_tris_kbd(ALL_PINS&~COL0); kbd=~COL0&ALL_PINS; break; case 1 : set_tris_kbd(ALL_PINS&~COL1); kbd=~COL1&ALL_PINS; break; case 2 : set_tris_kbd(ALL_PINS&~COL2); kbd=~COL2&ALL_PINS; break; case 3 : set_tris_kbd(ALL_PINS&~COL3); kbd=~COL3&ALL_PINS; break; } if(kbd_down) { if((kbd & (ALL_ROWS))==(ALL_ROWS)) { kbd_down=false; kchar=last_key; last_key='\0'; } } else { if((kbd & (ALL_ROWS))!=(ALL_ROWS)) { if((kbd & ROW0)==0) row=0; else if((kbd & ROW1)==0) row=1; else if((kbd & ROW2)==0) row=2; else if((kbd & ROW3)==0) row=3; last_key =KEYS[row][col]; kbd_down = true; } else { ++col; if(col==4) col=0; } } kbd_call_count=0; } set_tris_kbd(ALL_PINS); return(kchar); }
y este es un ejemplo donde al aplanar una tecla del teclado 4x4 te lo envia a la compu!
(yo no lo hice, por ahi me lo encontre jeje)
Código:#include <16f876a.h> #fuses XT,NOWDT,NOPROTECT,NOLVP,PUT,BROWNOUT #use delay(clock=4000000) #use fast_io(b) #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7) #include "kbd_lib.c" void main(){ char mitecla=0; kbd_init(); printf("\rKeyboard 4x4 monitor\r\r"; do { mitecla=kbd_getc(); if(mitecla!=0){ putc(mitecla); } } while (TRUE); }
#define use_porte_lcd TRUE //LCD conectado al puerto e
struct lcd_pin_map { // This structure is overlayed
BOOLEAN enable; //MODIFICADA PARA EASYPIC--------------------
BOOLEAN rs; //MODIFICADA PARA EASYPIC--------------------
BOOLEAN unused; // on to an I/O port to gain
BOOLEAN unused1; // access to the LCD pins.
// The bits are allocated from
// low order up. ENABLE will
int data : 4; // be pin B3-------------------------
} lcd;
#byte lcd = 0xF84
#define set_tris_lcd(x) set_tris_e(x)
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the 2nd line
byte const LCD_INIT_STRING[4] =
0x28 | (lcd_type << 2), // Func set: 4-bit, 2 lines, 5x8 dots
0xf, // Display on
1, // Clear display
6 // Increment cursor
struct lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
void lcd_send_nibble(byte nibble)
lcd.data = nibble;
delay_cycles(1);
lcd.enable = 1;
delay_us(2);
lcd.enable = 0;
// Send a byte to the LCD.
void lcd_send_byte(byte address, byte n)
lcd.rs = 0;
delay_us(3000);
lcd.rs = address;
delay_cycles(1);
lcd.enable = 0;
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init(void)
BYTE i;
set_tris_lcd(LCD_WRITE);
lcd.rs = 0;
lcd.enable = 0;
delay_ms(50);
lcd_send_nibble(2);
delay_ms(5);
for(i=0;i<=3;++i)
lcd_send_byte(0,LCD_INIT_STRING[i]);
delay_ms(5);
void lcd_gotoxy(byte x, byte y)
byte address;
if(y != 1)
address = lcd_line_two;
else
address=0;
address += x-1;
lcd_send_byte(0, 0x80 | address);
void lcd_putc(char c)
switch(c)
case '\f': //limpia pantalla
lcd_send_byte(0,1);
delay_ms(2);
break;
case '\n': //cambio de linea
lcd_gotoxy(1,2);
break;
case '\b': //retrocede 1 caracter
lcd_send_byte(0,0x10);
break;
default:
lcd_send_byte(1,c);
break;
void lcd_setcursor_vb(short visible, short blink)
lcd_send_byte(0, 0xC|(visible<<1)|blink);
Hola que tal yo solucione mi problema si alguien necesita el codigo aqui se los dejo... gracias igual por su ayuda...
Hola a todos
estoy programando en Ccs un 16f877a y la cosa es que necesito leer los bits del puerto E individualmente, tengo conectadas ahi resistencias y botones y de ahi a la fuente, tengo algo como esto
port_e_pullups(TRUE);
set_tris_E=(0b00000111);
if(bit_test(9,1))
// aqui irian las instrucciones en caso de que se este presionando el boton conectado al pin RE0
while(true){}
se que estoy haciendo algo mal porque no me sale o no se que me falte o que onda
mucho agradecere su ayuda
x=input_a() & 0b00000111; //Tomo solo los tres switches
switch(x){
case 0: //sentencia
case 1: //sentecnia
case ....
case 7: //ya que los tres interruptores toman un valor decimal de 7 cuando estan conectados los tres interruptores
if(INPUT(PIN_E0))
//insertar aqui código
while(TRUE)
pulsador=INPUT(PIN_E0);
if(pulsador==1)
//inserte aqui codigo
#bit BOTON = PORTE.0
if(BOTON)
//inserte aquí su codigo
#include <16F877.h>
#include <LCD420.c>
#define use_portb_lcd TRUE
void main() {
lcd_init();
lcd_putc("\f Hernan Alberto A. \n");
lcd_putc("Ejemplo LCD en CCS C");
