Diagramas Universales de TV LCD LED
Adjunto otros cuantos, más de 100 diagramas.
AKAI TV2111.pdf
AKIRA CT14F9.pdf
CHINA 11AK19 B.pdf
CHINA 11AK9.pdf
CHINA 2502 TV D.pdf
CHINA 25T8K TV D-STRG9656,HAIER8823,LA7840.pdf
CHINA 2720AT.pdf
CHINA 2913FT-TCLM13VOT,TB1240,STRF6656-TV D.pdf
CHINA 29K19-LC86F3348AU-DIP,LA76810A,STRF6656-TV D.pdf
CHINA 3418D-TA8772N,TB1204N-TV D.pdf
CHINA 34ST18-TMP87CM38N,TB1227AN-TV D.pdf
CHINA 36FK9 TV D.pdf
CHINA 3N01MK CHASSIS-MN152810,AN5195K-A-TV D.pdf
CHINA 3S10 CHASSIS-ST92185(ST92195),STV2248,STRG6653-TV SM.pdf
CHINA AT2156-Z90231,OM8838,TDA16846-TV D TCL.pdf
CHINA C2112-TMP87CK38N,TB1238AN-TV D.pdf
CHINA C2591-PCA84C841,TDA8362-TV D.pdf
CHINA CT 2015.pdf
CHINA CTV8259BT-PCA84C640,TA8659AN,STR6309-TV D.pdf
CHINA GT8821-MN142451,TA8659AN-TV D.pdf
CHINA GT8920-PCA84C440,TDA4505E-TV D.pdf
CHINO TVC 5044.pdf
DISNEY DT1900.pdf
DUBRAD DBTV 2500.pdf
DUBRAD DBTV 2702.pdf
KONKA T2563E-1.pdf
KONKA T2563E-2.pdf
KONKA T2563E.pdf
KONKA T2588N.pdf
KONKA T2966C1-1.pdf
KONKA T2966C1.pdf
LA 768.pdf
MEMOREX MT 1137.pdf
MEMOREZ 1098.pdf
OM 88.pdf
ONAWA K9921.pdf
PHILCO 20310.pdf
PHILCO TPF 2902.pdf
philco_cph_06m.pdf
PHILCO_CR14300.pdf
Royal 21CTV5 ST.pdf
Royal 28CTV5 TXT.pdf
ROYAL TV3735.pdf
TAURAS TV2K CHASSIS- ST92195,STV2248-TV SM[1].pdf
TAURAS TV3K CHASSIS-ST92195,STV2246-TV SM[1].pdf
TAURAS TV4K CHASSIS-ST92195PLSH,STV2246C-TV SM[2].pdf
TB 12.pdf
TCL-29DM182T.pdf
TCL -AT2156.pdf
TCL -AT2159D.pdf
TCL -AT2170.pdf
TCL -AT2186.pdf
TCL -AT2190.pdf
TCL -AT21S179.pdf
TCL -AT25192.pdf
TCL -AT2570U.pdf
TCL -AT25A192.pdf
TCL -AT25S168.pdf
TCL -AT25U159.pdf
TCL -AT2990.pdf
TCL -AT34106S.pdf
TCL -AT3416U.pdf
TCL -AT34187.pdf
TCL -AT34189B.pdf
TCL -AT34189E.pdf
TCL -AT3486DZ.pdf
TCL-CTV-21.pdf
TCL-TV-25.pdf
TCL-TV-29.pdf
TCL -V2999.pdf
TCL1701AS.pdf
TCL2101F.pdf
TCL2111D.pdf
TCL2133.pdf
TCL2169A.pdf
TCL2170.pdf
tcl2175e.pdf
TCL2188F.pdf
TCL2501A.pdf
TCL2502D.pdf
TCL2509S.pdf
TCL2509Z.pdf
TCL2516B.pdf
TCL2518E.pdf
TCL2533W.pdf
TCL2539W.pdf
TCL2568.pdf
TCL2901A.pdf
TCL2901NT.pdf
TCL2909A.pdf
TCL2910D.pdf
TCL2911DZ.pdf
TCL2911SD.pdf
TCL2913A.pdf
TCL2913FT.pdf
TCL2918.pdf
TCL2966.pdf
TCL2969A.pdf
TCL2980DB.pdf
TCL2999U.pdf
TCL3416DF.pdf
TCL3416DI.pdf
TCL3416DZ.pdf
TDA 93.pdf
TLM-1510EU LCD.pdf
TMP 88.pdf
TOKAI LT VHS 36.pdf
Igualmente se deben descargar todos los archivos (8 en total) para poder descomprimir o ver.
Se puede utilizar cualquier parte, siempre y cuando se encuentren todas en la misma carpeta.
Excelente aporte.!, necesitó diagrama main china tp.ms3393.p85. No arranca el primario de la fuente, revise MOSFET y no le llega la señal del oscilador, el problema está en que es un smd con codigo Mi1 o M11 y no se define bien, es de 6 pines SOT23. Saludos.!
Los diagramas esquemáticos de los tableros de TV de China se comparten en esta publicación para facilitar la resolución de problemas.
ejemplos:
Ver el archivo adjunto 298649Ver el archivo adjunto 298648
Listado:
Diagrama esquemático de TP.VST59S (TSUMV59S)
Diagrama esquemático de CV801LE-A-15
Diagrama esquemático de TP.VST59S.PB813
Diagrama esquemático de TP.VST59.P75
Diagrama esquemático de TP.VST59.PB818
TP.RD8503.PA671 Diagrama esquemático
Diagrama esquemático de CV59SH-DPW
Diagrama esquemático de TP.VST69D.PB818
Diagrama esquemático de CV338H-U42
P75-628VX-V6.0 MSD6A628 Diagrama esquemático
Diagrama esquemático de P75-3463GUV6
Diagrama esquemático de TP.MS1306.PB772
Diagrama esquemático T.EME380.61
T.VST29.30 Diagrama esquemático
TD.MS338.793 Diagrama esquemático
Diagrama esquemático de TP.HV530.PC821
Diagrama esquemático de TP.MS338.PC821
Diagrama esquemático de TP.MS608.PB831
Diagrama esquemático de TP.MS628.PB731
Diagrama esquemático de TP.MS628.PC737
Diagrama esquemático de TP.MS628.PC821
Diagrama esquemático de TP.MS638.PC821
Diagrama esquemático de TP.MS3393.PB818
Diagrama esquemático de TP.MS3393.PB851
Diagrama esquemático de TP.MS3463S.PB801
Diagrama esquemático de TP.MT5507.PC821
Diagrama esquemático de TP.S506.PB818
Diagrama esquemático de TP.S512.PB83
Diagrama esquemático de TP.S512.PC821
Diagrama esquemático de TP.V56.PB816
Diagrama esquemático de TP.V56.PC821
Diagrama esquemático de TP.VST59.P63
Diagrama esquemático de TP.VST59.P83
Diagrama esquemático de TP.VST59.PA671G
Diagrama esquemático de TP.VST59.PB819
Diagrama esquemático de TPD.MS338.PC798
Diagrama esquemático de TPD.MS338.PC799
Diagrama esquemático de TSUMV29LU
Diagrama esquemático de TP.HV320.PB752
Diagrama esquemático de TP.MS18VG.P77
Diagrama esquemático de TP.S506.PC821
Diagrama esquemático de TP.MS338.PB801
Diagrama esquemático de TP.MT5510I.PB801
Diagrama esquemático de TP.VST59S.PA501
Diagrama esquemático de TP.VST59S.PC815
Diagrama esquemático de TP.MS628.PB803
Diagrama esquemático de MSD3463-T8C1
Diagrama esquemático de TSUMV59-T4C2
35022105 Diagrama esquemático
Diagrama esquemático de TP.VST59S.P89
Nota:
Descargar todos los archivos y Descomprimir solo el primero con Winrar versión 6 en adelante. No tiene contraseña
Excelente aporte.! ✌💯Gracias!
Gracias por responder mi estimado tienes alguna idea de como identificar el modelo de la placa de este tv, estuve revisando y mire muchos números y la verdad no se cual seria el modelo de esta placa le tomare fotos y las subo para que me ayudes a reconocer la placa de este tv gracias por tu apoyo.
    156.6 KB · Visitas: 16
    175.5 KB · Visitas: 17
    179.7 KB · Visitas: 18
    148.3 KB · Visitas: 18
El modelo de la placa principal podría ser *35024201, pero no existe información sobre ese modelo.
Los TV HYUNDAI suelen usar placas JUC7.820.XXXXXXXX, busca por otros lados de la placa para ver si ves algo similar.
Como quiera, los técnicos actuales trabajamos sin diagramas, ya que el funcionamiento de las placas es muy similar entre todas.
Solo basta saber cómo funciona cada sector y cómo se realiza el proceso de arranque para determinar las posibles fallas.
Hola mi estimado te entiendo el problema que tengo, es que al dar la orden de encendido enciende el tv, tengo iluminación pero la pantalla queda en negro, se logra ver una pequeñas líneas en el inferior de la panta antes de desaparecer.
Por lo que e analizado tengo un corto en algún sector del panel, medí los voltajes y solo tengo los 12v de la main que llegan al panel los 3.3v de la parte digital los 1.8v también los demás voltajes al dar inicio se caen. Espero de su conocimiento para ver si me puedan ayudar con esta falla.
Desde ya les quedo muy agradecido.
Es más probable que el daño esté en un un chip COF que en el panel LCD.
El problema con ese tipo de T-CON integrada es que no es sencillo encontrar el COF defectuoso.
Muchas veces suele hacerse a prueba y error cortando las pistas CKV, pero si te equivocas de COF, tienes que reconstruir las pistas y cortar las del siguiente.
Y eso es en el dado caso de que el problema sea en el sector de sincronía, que es muy común y que aparte de producir una imagen doble, también el panel LCD puede quedar sin imagen, ya que actúa el sistema de protección del PMIC y corta las tensiones de operación.
En otras ocasiones se puede determinar qué COF está fallando midiendo la resistencia de las terminales y comparando con los otros, el que mida diferente será el dañado, pero esto es en raras ocasiones porque el daño puede estar muy interno y presentar la misma resistencia en las terminales que los otros.
Como la falta de las tensiones básicas de operación como VGL, VGH, VCOM etc, suele ser por protección, un problema muy común son capacitores SMD con fuga o en corto, así que esto es lo primero que se debe buscar.
Como la falta de las tensiones básicas de operación como VGL, VGH, VCOM etc, suele ser por protección, un problema muy común son capacitores SMD con fuga en corto, así que esto es lo primero que se debe buscar.
Gracias mi estimado por responder y aclarar un poco mas el panorama, voy a recurrir a un método de aplicar un bajo voltaje en el pin de los 15V AVDD, y luego ver que elemento o componente eleve temperatura, pues seria ese el causante del corto.
Una ves mas gracias por tu aporte mi estimado maestro.
voy a recurrir a un método de aplicar un bajo voltaje en el pin de los 15V AVDD, y luego ver qué elemento o componente eleve temperatura, pues sería ese el causante del corto.
Si no hay corto en la línea de AVDD no se debe aplicar voltaje, no tiene caso.
Y por cierto... solo se aplica bajo voltaje cuando este se desconoce, porque si sabes que en AVDD debe haber 15 V, puedes aplicar ese voltaje sin problemas.
Hola maestro le puse 3 voltios en AVDD y no se calentó ningún elemento, ni el voltaje tuvo ninguna caída, supongo que no hay corto y presumo que puede ser la main ya que esta se calienta demasiado en poco tiempo.
Por eso mencioné que si no hay corto no tiene caso inyectar voltaje.
Los cortos se miden en los capacitores con el multímetro en la posición de ohmetro.
En TV, una resistencia menor a 2 Ohms en algún capacitor ya significa que existe un corto.
Lo malo de mezclar inglés con español es que no se sabe a qué te refieres con "main".
Porque mainboard es placa principal o placa base, pero main es principal y puede referirse a varias cosas.
Así que, si con "main" te refieres al procesador o SoC, este suele calentarse mucho y en poco tiempo, pero hay que ver que tanto se calienta como determinar si es su temperatura normal o es excesiva.
Lo que sí no es normal es que el procesador se caliente cuando el TV no está operando, ya que sin operación está en estado de reposo o standby y su consumo es considerablemente bajo.
Yo inyecto 1.2 a 1.8 voltios con 2 amperios constantes para ver qué componente se calienta, me ha dado resultados. Uso fuente de laboratorio.
Hace tiempo reparé un tv que tenía ese problema y buscando y buscando...cambié dos condensadores que tenía que ver con el voltaje, en la tercera fotografía (tarjeta fuente) los condensadores están cerca del conector blanco de cables negros y azules. Esos tres capacitores electrolíticos que están en linea vertical hacia abajo ... muy cerca está un transformador. Saludos.
No se como subir la imagen recortada de la zona especifica...
Hola compañeros, les envió un cordial saludos, y en esta ocasión quiero compartir con ustedes una serie de Manuales de Servicio de Televisores Chinos que me encontré en la red, espero no tener ninguna sanción al compartir esta información con ustedes
Gracias.
  • FA + Main MSD3463-T8C1.pdf
    727.9 KB · Visitas: 43
  • FA + Main 35018470_35016968_35017303_35016536.pdf
    562.3 KB · Visitas: 43
  • FA + Mainboard CV338H-T42.pdf
    1.5 MB · Visitas: 49
  • FA + Mainboard CV338H-T42-13B.pdf
    1.2 MB · Visitas: 44
  • FA + Mainboard CV9202H-A39.pdf
    3.3 MB · Visitas: 44
  • FA + Mainboard MS308C1-ZC01-01.pdf
    403.6 KB · Visitas: 38
  • FA + Mainboard TP.MS3553.PB962.pdf
    690.2 KB · Visitas: 43
  • FA + Mainboard TP.VST59S.PB818_TP.VST59S.PB818-PB801.pdf
    388 KB · Visitas: 41
  • FA + Mainboard TP.RT2982.PB801.pdf
    3 MB · Visitas: 43
  • JUC7.820.00084054.pdf
    1.3 MB · Visitas: 43
  • LCD Philips 32PFL1508 Chasis PL13.8.pdf
    6.4 MB · Visitas: 49
  • LED LG 43UF7600 Chasis LA53J-1.pdf
    6.7 MB · Visitas: 49
    1.3 MB · Visitas: 34
    6.4 MB · Visitas: 43
    6.7 MB · Visitas: 44
  • Mainboard + FA RSAG7.820.5867.pdf
    697.2 KB · Visitas: 37
  • Mainboard 17MB120DS.pdf
    4.3 MB · Visitas: 49
  • Mainboard RSAG7.820.5842.pdf
    397.7 KB · Visitas: 36
  • Mainboard TP.MS3463S.PB818.pdf
    3.7 MB · Visitas: 44
  • MS308C1-YL01-01 Schematic Diagram.pdf
    363.7 KB · Visitas: 33
  • MSDV3224-YL01-01 Schematic Diagram.pdf
    297.9 KB · Visitas: 32
  • MSDV3223-YL01-01 Schematic Diagram.pdf
    295.9 KB · Visitas: 32
  • MS3393A.PA671 C14312 Schematic Diagram.PDF
    807.2 KB · Visitas: 32
  • MS308C1-ZC01-01 Schematic Diagram.pdf
    403.6 KB · Visitas: 30
  • MSDV3225-YL01-01 Schematic Diagram.pdf
    329.3 KB · Visitas: 33
  • MST6M58 Schematic Diagram.pdf
    1.1 MB · Visitas: 33
  • MST6U89 Schematic Diagram.pdf
    422.1 KB · Visitas: 32
  • T.MS6M181.7A.pdf
    216 KB · Visitas: 34
  • T.MS18VG.72B Schematic Diagram.PDF
    848.4 KB · Visitas: 33
  • T.MSD309.6X Schematic Diagram.pdf
    3.7 MB · Visitas: 38
  • T.MSD309.8B Schematic Diagram.pdf
    4.8 MB · Visitas: 44
  • T.MSD309.63A Schematic Diagram.pdf
    2.8 MB · Visitas: 40
  • TP.HV320.PB752 Schematic Diagram.pdf
    3.9 MB · Visitas: 41
  • TP.HV530.PC821 Schematics Diagram.pdf
    784.2 KB · Visitas: 34
  • TP.MS18VG.PB77 A13486 Schematic Diagram.pdf
    2.2 MB · Visitas: 37
  • TP.MS338.TB752 Schematic Diagram.pdf
    742.6 KB · Visitas: 37
  • TP.MS608.P83 Schematic Diagram.pdf
    4 MB · Visitas: 40
  • TP.MS628.PB803 A15111-规格书_A1.pdf
    2 MB · Visitas: 37
  • TP.MS628.PC821 A15116-规格书_A1.pdf
    4 MB · Visitas: 40
  • TP.MS638.PC758 A16050 Schematic Diagram.pdf
    1.3 MB · Visitas: 35
  • TP.MS638.PC821C15454 Schematics Diagram.PDF
    1.6 MB · Visitas: 36
  • TP.MS880.P78 C13485 Schematic Diagram.pdf
    809.5 KB · Visitas: 32
  • TP.MS3393.P851 Schematic Diagram.pdf
    529.4 KB · Visitas: 39
  • TP.MS3393.PB818 A15246 Schematic Diagram.PDF
    582.9 KB · Visitas: 35
  • TP.MS3393.PB851A Schematic Diagram.pdf
    1.9 MB · Visitas: 42
  • TP.MS3393.PC821.pdf
    4.9 MB · Visitas: 49
  • TP.MT5510I.PC821.pdf
    2.7 MB · Visitas: 40
  • TP.RT2982.PC821 B14355 Schematic Diagram.PDF
    439.5 KB · Visitas: 33
  • TP.S506.PB818 Schematic PDF.PDF
    1.1 MB · Visitas: 37
  • TP.S506.PC821 Schematic Diagram.PDF
    454.4 KB · Visitas: 35
  • TP.VS59.PB818 Schematic Diagram.pdf
    248.5 KB · Visitas: 39
Estimados compañeros, debido a que hay algunos archivos que están muy grandes o pesados, y no se pueden descargar o enviar, me voy a permitir enviar los enlaces donde ustedes podrán descargas directamente, les envió las correspondientes contraseñas para puedas descomprimir.
Contraseña: 20211
Contraseña: 2021
