#include "D:\BIOMETRICO\main.h"
  #include "D:\BIOMETRICO\24512_B.c"
  #include "D:\BIOMETRICO\KEY_B.c"
  #include "D:\BIOMETRICO\LCD_B.c"
  #include "D:\BIOMETRICO\DS1302_B.c"
  #include <ctype.h>
  #include <stdio.h>
  #include <stdlib.h>
  #include <string.h>
  #include <stdlibm.h>
  #include "input.c"
  /*#use fast_io (C)
  #use fast_io (A)
  #use fast_io (G)*/
  #priority RDA,RDA2
   char  buffer[822];
   char cadena[819];
   char buffer2[7];
   char c,d;
   unsigned long cont=0;
   int8 cont_GPRS=0;
   char cadena2[7];
   int1 flg_mensaje=0,flg_GPRS=0;
   char Codigo[5]=" ";
   int1 flg_mensaje2=0;
   char *digito;
   char hora[2];
   char minuto[2];
   char dia[2];
   char mes[2];
   char a_o[2];
   char a_o1[2];
   char opcion;
   int1 Flag=0;                           // Flag que cambia cada NInts interrupciones
   unsigned long i,j,length;
   int8 m,len;
   int iresult=1;
   int iresult1=1;
   int x;
   char HS[5] = {"2101"};
   char HM[5] = {"2102"};
   char HE[5] = {"2103"};
   char HR[5] = {"2199"};
   byte day,mth,year,dow,hour,min,sec;
#int_RDA
void  RDA_isr(void)
   disable_interrupts(INT_RDA2);
   c=0;
   c=getc();
   buffer[cont++]=c;
   if(c==0xf2){
      cont=0x00;
      flg_mensaje=1;
      clear_interrupt(INT_RDA);
      clear_interrupt(INT_RDA2);
      enable_interrupts(INT_RDA2);
#int_RDA2
void  RDA2_isr(void)
   disable_interrupts(INT_RDA);
   d=0;
   d=fgetc(GPRS);
   buffer2[cont_GPRS++]=d;
   if(d=='C'){
      cont_GPRS=0x00;
      flg_GPRS=1;
      enable_interrupts(INT_RDA);
void main()
   disable_interrupts(Global);
   setup_adc_ports(NO_ANALOGS|VSS_VDD);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED,0,1);
   setup_timer_3(T3_DISABLED|T3_DIV_BY_1);
   setup_timer_4(T4_DISABLED,0,1);
   setup_comparator(NC_NC_NC_NC);
   setup_vref(FALSE);
   disable_interrupts(GLOBAL);
   set_tris_b(0x00);
   set_tris_d(0x00);
   set_tris_e(0x00);
   set_tris_a(0b00100000);
   set_tris_c(0b10000000);
   set_tris_g(0b00000100);
   lcd_init();
   rtc_init();
   teclado_init();
   dow=1;
   digito=malloc(819);
   while (TRUE) {
     Menu:
      lcd_putc('\f');
      printf(lcd_putc," IDENTIFIQUESE: ");
      rtc_get_date( day, mth, year, dow);
      rtc_get_time( hour, min, sec );
      lcd_putc('\n');
      printf(lcd_putc,"%02u:%02u %02u-%02u-20%02u",hour,min,day,mth,year);
      InitBuffer();
      output_high(pin_d0);
      output_high(pin_d1);
      output_high(pin_d2);
      output_low(pin_d3);
      printf("ñ021DD7ò");
      //enable_interrupts(GLOBAL);
      //enable_interrupts(INT_RDA);
      //enable_interrupts(INT_RDA2);
      delay_ms(2000);
      do{
         if(flg_mensaje){
            length=strlen(buffer);
            if(length==822){
               Alarma();
               digito=InitBuffer1(819,digito);
               j=0;
               for(i=11;i<(819);i++){
                    digito[j]=buffer;
                    j++;
               fprintf(GPRS,"%S-20%02u%02u%02u %02u:%02u:%02u\r\n",digito,year,mth,day,hour,min,sec);
               fprintf(PC,"%S-20%02u%02u%02u %02u:%02u:%02u\r\n",digito,year,mth,day,hour,min,sec);
               lcd_putc('\f');
               lcd_putc(" HUELLA ENVIADA ");
               lcd_putc('\n');
               delay_ms(500);
               do{
                  if(flg_GPRS){
                     len=strlen(buffer2);
                     InitBufferRX2();
                     for(m=0;m<len;m++){
                        cadena2[m]=buffer2[m];
                     lcd_putc('\f');
                     lcd_putc("   PROCESANDO   ");
                     lcd_putc('\n');
                     lcd_putc("      DATO      ");
                     delay_ms(800);
                     iresult = strncmp  (cadena2,HS,4);
                     iresult1 = strncmp (cadena2,HM,4);
                     if (iresult==0 || iresult1==0 ){
                        lcd_putc('\f');
                        lcd_putc("   CODIGO:    ");
                        lcd_putc('\n');
                        delay_ms(300);
                        for(m=0;m<len;m++){
                           if (cadena2[m]=='-'){
                              for(x=0;x<4;x++){
                                 codigo[x]=cadena2[m];
                                 if (x==0)
                                    printf(lcd_putc,"      %c      ",codigo[x]);
                                 if (x==1)
                                 if (x==2)
                                 if (x==3)
                                 delay_ms(300);
                                 m++;
                        /*lcd_putc('\f');
                        lcd_putc('\n');
                        printf(lcd_putc,"      %S      ",codigo);*/
                        delay_ms(1000);
                        Alarma();
                        iresult=1;
                        iresult1=1;
                     }else{
                        iresult = strncmp  (cadena2,HE,4);
                        iresult1 = strncmp (cadena2,HR,4);
                        if(iresult==0 || iresult1==0){
                           output_bit (pin_B5, 1);
                           delay_ms(1500);
                           lcd_putc('\f');
                           lcd_putc(" IDENTIFIQUESE: ");
                           lcd_putc('\n');
                           lcd_putc("   NUEVAMENTE   ");
                           delay_ms(1000);
                     flg_mensaje2=1;
                     flg_GPRS=0;
                  }else{
                     flg_mensaje2=0;
               }while(flg_mensaje2!=1);
               flag=1;
               flg_mensaje=0;
         }else{
            flag=0;
      }while(flag!=1);
      flag=0;
