Son PWM Aca te pego las eapecificaciones de ese mismo q pusiste
http://m.aliexpress.com/item/1836815674.html
45 usd muy caro. Lo fabricas por 10 usd
0% Brand new , never used
Item\'s color might be different from the picture because of the aberration.
This Dimmer allows stepless dimming,the user can adjust brightness of the light to the appropriate
according to actual needs use knob control.
Features:
Low power consumption and energy-saving.
Easy operation, just twirl a black knob to adjust the brightness of LED lights .
Adjust the light soft and stable, no flickering.
Can reduce the times and cost of replacement lamps.
PWM digital dimming, avoid rush current, protect your LED lights.
Mainly use to adjust single color LED light / lamps.
Constand voltage and constand current output, can be connected with amplifiers to extend its load.
Supply voltage of this product is DC12-24V;never connect to AC110V or AC220V.
Application:For MR16 LED Spot Light,LED Strip Light,24V LED Tube Light and other 12 / 24V LED Lights /
Lamps.
Specification:
Working Temperature: -20~60C
Supply Voltage
C 12-24V
Max load Current: 8A
Output: 1 Channel 96W 12V (0-8A )
Static power consumption: 1W
Function: can achieve stepless dimming
Net Weight: 63g
Dimension:9cm x 6cm x 3.5cm/3.54inch x 2.36inch x 1.38inch
Package Included:
5 x 12-24V 8A Led Dimmer
