#IFNDEF __USB_DESCRIPTORS__
#DEFINE __USB_DESCRIPTORS__
///////// config options, although it's best to leave alone for this demo /////
#define  USB_CONFIG_PID       0x0022
#define  USB_CONFIG_VID       0x0461
#define  USB_CONFIG_BUS_POWER 100   //100mA  (range is 0..500)
#define  USB_CONFIG_VERSION   0x0200      //01.00  //range is 00.00 to 99.99
//////// end config ///////////////////////////////////////////////////////////
#DEFINE USB_HID_DEVICE  TRUE  //Tells the CCS PIC USB firmware
                              //to include HID handling code.
//turn on EP1 for IN interrupt transfers.  (IN = PIC -> PC)
#define USB_EP1_TX_ENABLE  USB_ENABLE_INTERRUPT
#define USB_EP1_TX_SIZE 8     //max packet size of this endpoint
#include <usb.h>
   ///  HID Report.  Tells HID driver how to handle and deal with
   ///  received data.  HID Reports can be extremely complex,
   ///  see HID specifcation for help on writing your own.
   ///  This examples configures HID driver to take received data
   ///  as mouse x, y and button data.
   const char USB_CLASS_SPECIFIC_DESC[] =
      0x05, 0x01,                    // USAGE_PAGE (Generic Desktop)
      0x15, 0x00,                    // LOGICAL_MINIMUM (0)
      0x09, 0x04,                    // USAGE (Joystick)
      0xa1, 0x01,                    // COLLECTION (Application)
      0x05, 0x02,                    //   USAGE_PAGE (Simulation Controls)
      0x09, 0xbb,                    //   USAGE (Throttle)
      0x26, 0xff, 0x00,                    //   LOGICAL_MAXIMUM (255)
      0x75, 0x08,                    //   REPORT_SIZE (10)
      0x95, 0x01,                    //   REPORT_COUNT (1)
      0x81, 0x02,                    //   INPUT (Data,Var,Abs)
      0x09, 0x01,                    //   USAGE (Pointer)
      0xa1, 0x00,                    //   COLLECTION (Physical)
      0x09, 0x30,                    //     USAGE (X)
      0x09, 0x31,                    //     USAGE (Y)
      0x95, 0x02,                    //     REPORT_COUNT (2)
      0xc0,                          //   END_COLLECTION
      0x09, 0x39,                    //   USAGE (Hat switch)
      0x25, 0x03,                    //   LOGICAL_MAXIMUM (3)
      0x35, 0x00,                    //   PHYSICAL_MINIMUM (0)
      0x46, 0x0e, 0x01,              //   PHYSICAL_MAXIMUM (270)
      0x65, 0x14,                    //   UNIT (Eng Rot:Angular Pos)
      0x75, 0x04,                    //   REPORT_SIZE (4)
      0x05, 0x09,                    //   USAGE_PAGE (Button)
      0x19, 0x01,                    //   USAGE_MINIMUM (Button 1)
      0x29, 0x04,                    //   USAGE_MAXIMUM (Button 4)
      0x25, 0x01,                    //   LOGICAL_MAXIMUM (1)
      0x75, 0x01,                    //   REPORT_SIZE (1)
      0x95, 0x04,                    //   REPORT_COUNT (4)
      0x55, 0x00,                    //   UNIT_EXPONENT (0)
      0x65, 0x00,                    //   UNIT (None)
      0xc0                           // END_COLLECTION
   //if a class has an extra descriptor not part of the config descriptor,
   // this lookup table defines where to look for it in the const
   // USB_CLASS_SPECIFIC_DESC[] array.
   //first element is the config number (if your device has more than one config)
   //second element is which interface number
   //set element to 0xFFFF if this config/interface combo doesn't exist
   const int16 USB_CLASS_SPECIFIC_DESC_LOOKUP[USB_NUM_CONFIGURATIONS][1] =
   //config 1
      //interface 0
         0
   // this lookup table defines the size of that descriptor.
   const int16 USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[USB_NUM_CONFIGURATIONS][1] =
   //config 1
      //interface 0
      sizeof(USB_CLASS_SPECIFIC_DESC)
///   start config descriptor
///   right now we only support one configuration descriptor.
///   the config, interface, class, and endpoint goes into this array.
   #DEFINE USB_TOTAL_CONFIG_LEN      34 //config+interface+class+endpoint
   const char USB_CONFIG_DESC[] = {
   //IN ORDER TO COMPLY WITH WINDOWS HOSTS, THE ORDER OF THIS ARRAY MUST BE:
      //    config(s)
      //    interface(s)
      //    class(es)
      //    endpoint(s)
   //config_descriptor for config index 1
         USB_DESC_CONFIG_LEN, //length of descriptor size          ==1
         USB_DESC_CONFIG_TYPE, //constant CONFIGURATION (CONFIGURATION 0x02)     ==2
         USB_TOTAL_CONFIG_LEN,0, //size of all data returned for this config      ==3,4
         1, //number of interfaces this device supports       ==5
         0x01, //identifier for this configuration.  (IF we had more than one configurations)      ==6
         0x00, //index of string descriptor for this configuration      ==7
        #if USB_CONFIG_BUS_POWER
         0xC0, //bit 6=1 if self powered, bit 5=1 if supports remote wakeup (we don't), bits 0-4 unused and bit7=1         ==8
        #else
         0x80, //bit 6=1 if self powered, bit 5=1 if supports remote wakeup (we don't), bits 0-4 unused and bit7=1         ==8
        #endif
         USB_CONFIG_BUS_POWER/2, //maximum bus power required (maximum milliamperes/2)  (0x32 = 100mA)   ==9
   //interface descriptor 1
         USB_DESC_INTERFACE_LEN, //length of descriptor      =10
         USB_DESC_INTERFACE_TYPE, //constant INTERFACE (INTERFACE 0x04)       =11
         0x00, //number defining this interface (IF we had more than one interface)    ==12
         0x00, //alternate setting     ==13
         1, //number of endpoints, except 0     ==14
         0x03, //class code, 03 = HID     ==15
         0x01, //subclass code //boot     ==16
         0x02, //protocol code      ==17
         0x00, //index of string descriptor for interface      ==18
   //class descriptor 1  (HID)
         USB_DESC_CLASS_LEN, //length of descriptor    ==19
         USB_DESC_CLASS_TYPE, //dscriptor type (0x21 == HID)      ==20
         0x00,0x01, //hid class release number (1.0) (try 1.10)      ==21,22
         0x00, //localized country code (0 = none)       ==23
         0x01, //number of hid class descrptors that follow (1)      ==24
         0x22, //report descriptor type (0x22 == HID)                ==25
         USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[0][0], 0x00, //length of report descriptor            ==26,27
   //endpoint descriptor
         USB_DESC_ENDPOINT_LEN, //length of descriptor                   ==28
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)          ==29
         0x81, //endpoint number and direction (0x81 = EP1 IN)       ==30
         USB_ENDPOINT_TYPE_INTERRUPT, //transfer type supported (0x03 is interrupt)         ==31
         USB_EP1_TX_SIZE,0x00, //maximum packet size supported                  ==32,33
         10  //polling interval, in ms.  (cant be smaller than 10 for slow speed devices)     ==34
   //****** BEGIN CONFIG DESCRIPTOR LOOKUP TABLES ********
   //since we can't make pointers to constants in certain pic16s, this is an offset table to find
   //  a specific descriptor in the above table.
   //NOTE: DO TO A LIMITATION OF THE CCS CODE, ALL HID INTERFACES MUST START AT 0 AND BE SEQUENTIAL
   //      FOR EXAMPLE, IF YOU HAVE 2 HID INTERFACES THEY MUST BE INTERFACE 0 AND INTERFACE 1
   #define USB_NUM_HID_INTERFACES   1
   //the maximum number of interfaces seen on any config
   //for example, if config 1 has 1 interface and config 2 has 2 interfaces you must define this as 2
   #define USB_MAX_NUM_INTERFACES   1
   //define how many interfaces there are per config.  [0] is the first config, etc.
   const char USB_NUM_INTERFACES[USB_NUM_CONFIGURATIONS]={1};
   //define where to find class descriptors
   //first dimension is the config number
   //second dimension specifies which interface
   //last dimension specifies which class in this interface to get, but most will only have 1 class per interface
   //if a class descriptor is not valid, set the value to 0xFFFF
   const int16 USB_CLASS_DESCRIPTORS[USB_NUM_CONFIGURATIONS][USB_NUM_HID_INTERFACES][1]=
   //config 1
      //interface 0
         //class 1
         18
   #if (sizeof(USB_CONFIG_DESC) != USB_TOTAL_CONFIG_LEN)
      #error USB_TOTAL_CONFIG_LEN not defined correctly
   #endif
///   start device descriptors
   const char USB_DEVICE_DESC[] = {
      //starts of with device configuration. only one possible
         USB_DESC_DEVICE_LEN, //the length of this report   ==1
         0x01, //the constant DEVICE (DEVICE 0x01)  ==2
         0x10,0x01, //usb version in bcd (pic167xx is 1.1) ==3,4
         0x00, //class code ==5
         0x00, //subclass code ==6
         0x00, //protocol code ==7
         USB_MAX_EP0_PACKET_LENGTH, //max packet size for endpoint 0. (SLOW SPEED SPECIFIES 8) ==8
         USB_CONFIG_VID & 0xFF, ((USB_CONFIG_VID >> 8) & 0xFF), //vendor id       ==9, 10
         USB_CONFIG_PID & 0xFF, ((USB_CONFIG_PID >> 8) & 0xFF), //product id, don't use 0xffff       ==11, 12
         USB_CONFIG_VERSION & 0xFF, ((USB_CONFIG_VERSION >> 8) & 0xFF), //device release number  ==13,14
         0x01, //index of string description of manufacturer. therefore we point to string_1 array (see below)  ==15
         0x02, //index of string descriptor of the product  ==16
         0x00, //index of string descriptor of serial number  ==17
         USB_NUM_CONFIGURATIONS  //number of possible configurations  ==18
   #if (sizeof(USB_DEVICE_DESC) != USB_DESC_DEVICE_LEN)
      #error USB_DESC_DEVICE_LEN not defined correctly
   #endif
///   start string descriptors
///   String 0 is a special language string, and must be defined.  People in U.S.A. can leave this alone.
//the offset of the starting location of each string.  offset[0] is the start of string 0, offset[1] is the start of string 1, etc.
const char USB_STRING_DESC_OFFSET[]={0,4,12};
//number of strings you have, including string 0.
#define USB_STRING_DESC_COUNT sizeof(USB_STRING_DESC_OFFSET)
// Here is where the "CCS" Manufacturer string and "CCS USB Mouse" are stored.
// Strings are saved as unicode.
char const USB_STRING_DESC[]={
   //string 0
         4, //length of string index
         USB_DESC_STRING_TYPE, //descriptor type 0x03 (STRING)
         0x09,0x04,   //Microsoft Defined for US-English
   //string 1
         8, //length of string index
         'C',0,
         'C',0,
         'S',0,
   //string 2
         28, //length of string index
         'C',0,
         'C',0,
         'S',0,
         ' ',0,
         'U',0,
         'S',0,
         'B',0,
         ' ',0,
         'M',0,
         'o',0,
         'u',0,
         's',0,
         'e',0
