mmm no las conexiónes estan perfectas , intente con varios parlantes y cables, y nada por eso es q me juego mas porque sean los driver faltantes o erroneos pero no los puedo encontrar en ningun lado
tengo win 98 se por si les ayuda para ayudarme
encontre esto en internet pero nose como configuralo ni en donde en esta pagina:
http://www.frankb.us/stuff/OmniBook3000CTX.html#sound
cita:
Sound support
I have now gotten sound to work in a way. My kernel is compiled with module support (but not MODVERSIONS) so getting sound to work was simply a question of loading properly compiled module into the kernel.
In later kernels than the 2.0.35 I'm using, some of the entries that need to be specified don't appear in the configuration menu, and I've not been able to make sound work with these newer kernels. Perhaps it'll be back and working in 2.2
The config settings I used for building the sound module are given below Sound card support M
Support for Crystal CS4232 based (PnP) cards *
/dev/dsp and /dev/audio support *
CS4232 audio I/O base 530
CS4232 audio IRQ 5
CS4232 audio DMA 1
CS4232 second (duplex) DMA 0
CS4232 MIDI I/O base 330
CS4232 MIDI IRQ 9
Audio DMA buffer size 65536
The corresponding portion of the config file look like this:
# Sound
CONFIG_SOUND=m
# CONFIG_PAS is not set
# CONFIG_SB is not set
CONFIG_ADLIB=y
# CONFIG_GUS is not set
# CONFIG_MPU401 is not set
# CONFIG_UART6850 is not set
# CONFIG_PSS is not set
# CONFIG_GUS16 is not set
# CONFIG_GUSMAX is not set
# CONFIG_MSS is not set
# CONFIG_SSCAPE is not set
# CONFIG_TRIX is not set
# CONFIG_MAD16 is not set
CONFIG_CS4232=y
# CONFIG_MAUI is not set
CONFIG_AUDIO=y
CONFIG_MIDI=y
# CONFIG_YM3812 is not set
CS4232_BASE=530
CS4232_IRQ=5
CS4232_DMA=1
CS4232_DMA2=0
CS4232_MPU_BASE=330
CS4232_MPU_IRQ=9
DSP_BUFFSIZE=65536
# CONFIG_LOWLEVEL_SOUND is not set
tienen idea q es o donde ponerlo?
