Os dejo un video, que seguro a la gente que le gusta hacer fuentes commutadas querria una novia asi...jejeje
http://www.impactante.tv/2012/03/19/manos-super-rapidas/
y esa cinta amarilla como se llama
¿y donde está la novia??? todo lo que veo es un robot...![]()
la alta tensión en plasma fluye por la piel no pudiendo afectar el cuerpo humano se llama efecto piel y pasa porque la intensidad esta re desfasada de la tensión que a su vez esta elevadicima es el concepto de aceleración
High frequency electrical safety
Student conducting Tesla coil streamers through his body, 1909
[edit] The 'skin effect'
The dangers of contact with high frequency electrical current are sometimes perceived as being less than at lower frequencies, because the subject usually doesn't feel pain or a 'shock'. This is often erroneously attributed to skin effect, a phenomenon that tends to inhibit alternating current from flowing inside conducting media. It was thought that in the body, Tesla currents travelled close to the skin surface, making them safer than lower frequency electric currents. In fact, in the early 1900s a major use of Tesla coils was to apply high frequency current directly to the body in electrotherapy.
Although skin effect limits Tesla currents to the outer fraction of an inch in metal conductors, the 'skin depth' of human flesh at typical Tesla coil frequencies is still of the order of 60 inches (150 cm) or more.[39][40][41][42][43] This means that high frequency currents will still preferentially flow through deeper, better conducting, portions of an experimenter's body such as the circulatory and nervous systems. The reason for the lack of pain is that a human being's nervous system does not sense the flow of potentially dangerous electrical currents above 15–20 kHz; essentially, in order for nerves to be activated, a significant number of ions must cross their membrane before the current (and hence voltage) reverses. Since the body no longer provides a warning 'shock', novices may touch the output streamers of small Tesla coils without feeling painful shocks. However, there is anecdotal evidence among Tesla coil experimenters that temporary tissue damage may still occur and be observed as muscle pain, joint pain, or tingling for hours or even days afterwards. This is believed to be caused by the damaging effects of internal current flow, and is especially common with continuous wave (CW), solid state or vacuum tube type Tesla coils. Some transformers can provide alternating current with such high frequencies that the skin depth becomes small enough for the voltage to be safe.citation needed Skin depth is inversely proportional to the root of the frequency, putting these frequencies in the megahertz range.
Los peligros del contacto con corriente eléctrica de alta frecuencia a veces se percibe como menor que en las frecuencias más bajas, porque por lo general no se siente dolor o un "shock". Esto es a menudo erróneamente atribuido al efecto pelicular (efecto skin), un fenómeno que tiende a inhibir el flujo de corriente dentro de los conductores. Se pensaba que en el cuerpo, las corrientes de Tesla viajan cerca de la superficie de la piel, siendo más seguras que las corrientes eléctricas de baja frecuencia. De hecho, en el año 1900 el mayor uso de bobinas de Tesla consistía en aplicar corriente de alta frecuencia directamente al cuerpo, en sesiones de electroterapia.
Aunque el efecto pelicular limita las corrientes de Tesla a la fracción externa de una pulgada de conductores metálicos, la "profundidad" en la carne humana en las frecuencias típicas de la bobina de Tesla es del orden de 60 pulgadas (150 cm) o más. [39] [40 ] [41] [42] [43] Esto significa que las corrientes de alta frecuencia fluyen aún preferentemente a través del cuerpo del experimentador, incluyendo los sistemas circulatorio y nervioso. La razón de la ausencia de dolor es que el sistema nervioso de un ser humano no detecta el flujo de corrientes eléctricas potencialmente peligrosas por encima de 15-20 kHz; esencialmente porque, para que los nervios sean activados, un número significativo de iones deben cruzar su membrana antes que la corriente (y por tanto de tensión) se invierta. Puesto que el cuerpo no ofrece el 'shock' de advertencia, los principiantes pueden tocar los cables de salida de pequeñas bobinas de Tesla sin sentir dolorosos shocks. Sin embargo, hay evidencia de que en experimentadores de bobinas Tesla, el daño en los tejidos se puede seguir produciendo y ser observado como un dolor muscular, dolor en las articulaciones u hormigueo durante horas o incluso días después. Esto se cree que es causada por los efectos dañinos del flujo de corriente interna, y es especialmente común con la onda continua (CW), bobinas de Tesla de estado sólido o de vacío con cámara. Algunos transformadores pueden proporcionar corriente alterna con frecuencias tan altas que la profundidad de la piel se vuelve suficientemente pequeña para que el voltaje sea seguro (cita necesaria). La profundidad de la piel es inversamente proporcional a la raíz de la frecuencia, lo que pone estas frecuencias en el rango de megahercios.
