// duplex config flags
#define Spi_Ethernet_HALFDUPLEX 0x00 // half duplex
#define Spi_Ethernet_FULLDUPLEX 0x01 // full duplex
// mE ehternet NIC pinout
sfr sbit SPI_Ethernet_Rst at RC0_bit;
sfr sbit SPI_Ethernet_CS at RC1_bit;
sfr sbit SPI_Ethernet_Rst_Direction at TRISC0_bit;
sfr sbit SPI_Ethernet_CS_Direction at TRISC1_bit;
// end ethernet NIC definitions
* ROM constant strings
const unsigned char httpHeader[] = "HTTP/1.1 200 OKnContent-type: " ; // HTTP header
const unsigned char httpMimeTypeHTML[] = "text/htmlnn" ; // HTML MIME type
const unsigned char httpMimeTypeScript[] = "text/plainnn" ; // TEXT MIME type
unsigned char httpMethod[] = "GET /";
* web page, splited into 2 parts :
* when coming short of ROM, fragmented data is handled more efficiently by linker
* this HTML page calls the boards to get its status, and builds itself with javascript
const char *indexPage = // Change the IP address of the page to be refreshed
"<meta http-equiv="refresh" content="3;url=http://192.168.20.60">
<HTML><HEAD></HEAD><BODY>
<h1>PIC + ENC28J60 Mini Web Server</h1>
<a href=/>Reload</a>
<script src=/s></script>
<table><tr><td valign=top><table border=1 style="font-size:20px ;font-family: terminal ;">
<tr><th colspan=2>ADC</th></tr>
<tr><td>AN2</td><td><script>document.write(AN2)</script></td></tr>
<tr><td>AN3</td><td><script>document.write(AN3)</script></td></tr>
</table></td><td><table border=1 style="font-size:20px ;font-family: terminal ;">
<tr><th colspan=2>PORTB</th></tr>
<script>
var str,i;
str="";
for(i=0;i<8;i++)
{str+="<tr><td bgcolor=pink>BUTTON #"+i+"</td>";
if(PORTB&(1<<i)){str+="<td bgcolor=red>ON";}
else {str+="<td bgcolor=#cccccc>OFF";}
str+="</td></tr>";}
document.write(str) ;
</script>
const char *indexPage2 = "</table></td><td>
<tr><th colspan=3>PORTD</th></tr>
<script>
var str,i;
str="";
for(i=0;i<8;i++)
{str+="<tr><td bgcolor=yellow>LED #"+i+"</td>";
if(PORTD&(1<<i)){str+="<td bgcolor=red>ON";}
str+="</td><td><a href=/t"+i+">Toggle</a></td></tr>";}
</script>
</table></td></tr></table>
This is HTTP request #<script>document.write(REQ)</script></BODY></HTML>
* RAM variables
unsigned char myMacAddr[6] = {0x00, 0x14, 0xA5, 0x76, 0x19, 0x3f}; // my MAC address
unsigned char myIpAddr[4] = {192, 168, 20, 60}; // my IP address
unsigned char getRequest[15]; // HTTP request buffer
unsigned char dyna[30]; // buffer for dynamic response
unsigned long httpCounter = 0; // counter of HTTP requests
* functions
* put the constant string pointed to by s to the ENC transmit buffer.
/*unsigned int putConstString(const char *s)
unsigned int ctr = 0 ;
while(*s)
Spi_Ethernet_putByte(*s++) ;
ctr++ ;
return(ctr) ;
* it will be much faster to use library Spi_Ethernet_putConstString routine
* instead of putConstString routine above. However, the code will be a little
* bit bigger. User should choose between size and speed and pick the implementation that
* suites him best. If you choose to go with the putConstString definition above
* the #define line below should be commented out.
#define putConstString SPI_Ethernet_putConstString
* put the string pointed to by s to the ENC transmit buffer
/*unsigned int putString(char *s)
while(*s)
Spi_Ethernet_putByte(*s++);
ctr++;
return(ctr);
* it will be much faster to use library Spi_Ethernet_putString routine
* instead of putString routine above. However, the code will be a little
* suites him best. If you choose to go with the putString definition above
#define putString SPI_Ethernet_putString
* this function is called by the library
* the user accesses to the HTTP request by successive calls to Spi_Ethernet_getByte()
* the user puts data in the transmit buffer by successive calls to Spi_Ethernet_putByte()
* the function must return the length in bytes of the HTTP reply, or 0 if nothing to transmit
* if you don't need to reply to HTTP requests,
* just define this function with a return(0) as single statement
unsigned int SPI_Ethernet_UserTCP(unsigned char *remoteHost, unsigned int remotePort, unsigned int localPort, unsigned int reqLength)
unsigned int len = 0; // my reply length
unsigned int i; // general purpose integer
if(localPort != 80) // I listen only to web request on port 80
return(0);
// get 10 first bytes only of the request, the rest does not matter here
for(i = 0; i < 10; i++)
getRequest[i] = SPI_Ethernet_getByte();
getRequest[i] = 0;
if(memcmp(getRequest, httpMethod, 5)) // only GET method is supported here
return(0);
httpCounter++; // one more request done
if(getRequest[5] == 's') // if request path name starts with s, store dynamic data in transmit buffer
// the text string replied by this request can be interpreted as javascript statements
// by browsers
len = putConstString(httpHeader); // HTTP header
len += putConstString(httpMimeTypeScript); // with text MIME type
// add AN2 value to reply
IntToStr(ADC_Read(2), dyna);
len += putConstString("var AN2=");
len += putString(dyna);
len += putConstString(";");
// add AN3 value to reply
IntToStr(ADC_Read(3), dyna);
len += putConstString("var AN3=");
// add PORTB value (buttons) to reply
len += putConstString("var PORTB=");
IntToStr(PORTB, dyna);
// add PORTD value (LEDs) to reply
len += putConstString("var PORTD=");
IntToStr(PORTD, dyna);
// add HTTP requests counter to reply
IntToStr(httpCounter, dyna);
len += putConstString("var REQ=");
else if(getRequest[5] == 't') // if request path name starts with t, toggle PORTD (LED) bit number that comes after
unsigned char bitMask = 0; // for bit mask
if(isdigit(getRequest[6])) // if 0 <= bit number <= 9, bits 8 & 9 does not exist but does not matter
bitMask = getRequest[6] - '0'; // convert ASCII to integer
bitMask = 1 << bitMask; // create bit mask
PORTD ^= bitMask; // toggle PORTD with xor operator
if(len == 0) // what do to by default
len += putConstString(httpMimeTypeHTML); // with HTML MIME type
len += putConstString(indexPage); // HTML page first part
len += putConstString(indexPage2); // HTML page second part
return(len); // return to the library with the number of bytes to transmit
* the user accesses to the UDP request by successive calls to Spi_Ethernet_getByte()
* the function must return the length in bytes of the UDP reply, or 0 if nothing to transmit
* if you don't need to reply to UDP requests,
unsigned int SPI_Ethernet_UserUDP(unsigned char *remoteHost, unsigned int remotePort, unsigned int destPort, unsigned int reqLength)
unsigned int len; // my reply length
unsigned char *ptr; // pointer to the dynamic buffer
// reply is made of the remote host IP address in human readable format
ByteToStr(remoteHost[0], dyna); // first IP address byte
dyna[3] = '.';
ByteToStr(remoteHost[1], dyna + 4); // second
dyna[7] = '.';
ByteToStr(remoteHost[2], dyna + 8); // third
dyna[11] = '.';
ByteToStr(remoteHost[3], dyna + 12); // fourth
dyna[15] = ':'; // add separator
// then remote host port number
WordToStr(remotePort, dyna + 16);
dyna[21] = '[';
WordToStr(destPort, dyna + 22);
dyna[27] = ']';
dyna[28] = 0;
// the total length of the request is the length of the dynamic string plus the text of the request
len = 28 + reqLength;
// puts the dynamic string into the transmit buffer
SPI_Ethernet_putBytes(dyna, 28);
// then puts the request string converted into upper char into the transmit buffer
while(reqLength--)
SPI_Ethernet_putByte(toupper(SPI_Ethernet_getByte()));
return(len); // back to the library with the length of the UDP reply
* main entry
void main()
ANSEL = 0x0C; // AN2 and AN3 convertors will be used
PORTA = 0;
TRISA = 0xff; // set PORTA as input for ADC
ANSELH = 0; // Configure other AN pins as digital I/O
PORTB = 0;
TRISB = 0xff; // set PORTB as input for buttons
PORTD = 0;
TRISD = 0; // set PORTD as output
* starts ENC28J60 with :
* reset bit on RC0
* CS bit on RC1
* my MAC & IP address
* full duplex
SPI1_Init();
SPI_Ethernet_Init(myMacAddr, myIpAddr, Spi_Ethernet_FULLDUPLEX);
while(1) // do forever
* if necessary, test the return value to get error code
SPI_Ethernet_doPacket(); // process incoming Ethernet packets
* add your stuff here if needed
* Spi_Ethernet_doPacket() must be called as often as possible
* otherwise packets could be lost
