TV Debugging Tool
Si sabes de algún comando o método, lo puedes compartir y se agrega.
Desafortunadamente, no conozco ese comando, pero por experiencia he descubierto que se conecta a través de la pestaña Mstar.
<< MT5867 >># AC_ON
01-2L-SM-03-20210812
9TH
MIU0_DQS-OK
BIST0-OK
BAP=1
BAP=1
optee teeloader entry
MultiOptee image detected, ModelID=00000000
CusConfig
eMMC_RPMB_Check_Program_Key
BAP=1
BAP=1
ree_opt=0000007B
BAP=1
Auth reeloader...
Decrypt reeloader...
Check reeloader magic ID...
Version check on reeloader...
BAP=1
BAP=1
Auth CKB...
Decrypt CKB...
Check CKB magic ID...
ns_uboot_boot
NOTICE: BL3-1: v1.1(debug):342a5851
NOTICE: BL3-1: Built : 20:55:55, Dec 26 2021
INFO: BL3-1: Initializing runtime services
INFO: [0;32;31m [Booting] mstar_send_magic_ATF 496 [m
INFO: BL3-1: Initializing BL3-2
[Ramlog] ramlog_init init success
INFO: BL3-1: Preparing for EL3 exit to normal world
INFO: BIN1_32bit mode Dec 26 2021 20:55:55
INFO: R1 0
INFO: R2 0
INFO: R3 0
ree_entry
U[AT][MB][start ub][583]
U-Boot 2011.06-dirty (Jun 30 2022 - 17:23:03)
[Mboot] ===== sw IR Config Register =====
[Mboot] ===== Attach IR Interrupt ======
Uboot Relocation: 152 MiB
eMMC HS400 5.1 200MHz
eMMC 7.28 GB
eMMC used life: 0~10%
CID
0x008A66F4
0x73810652
0x34465447
0x38000115
<< MT5867 >>#
Hice clic en la primera opción, Invertir, en la pestaña Mstar.
La imagen no ha cambiado.
<< MT5867 >># env edit MIRROR_ON 0
edit: save
<< MT5867 >># reset
[AT][MB][start do_reset]
do_reset: Using RIU_MAP: 0x1F000000, at 55
UART_115200
AC_ON
9TH
MIU0_DQS-OK
BIST0-OK
BAP=1
BAP=1
CusConfig
BAP=1
BAP=1
ree_opt=0000007B
BAP=1
Auth reeloader...
BAP=1
BAP=1
Auth CKB...
Decrypt CKB...
ns_uboot_boot
INFO: R1 0
INFO: R2 0
INFO: R3 0
ree_entry
eMMC 7.28 GB
CID
0x008A66F4
0x73810652
0x34465447
0x38000115
[CVTE]Wakeup intercept 1.5S
CRC Check OPEN: 1
[CVTE] PM VERSION:Apr 17 2021,00:23:28
WOW_GPIO_NUM = 0
WOW_GPIO_NUM is invalid
WOBT_GPIO_NUM = 255
WOBT_PM_GPIO_NUM = 255
WOEWBS_GPIO_NUM = 255
WOEWBS_PM_GPIO_NUM = 255
BTW = FF
USB = FF
VAD = FF
0x8701
Hice clic en la segunda opción, "Invertir", en la pestaña Mstar.
<< MT5867 >># env edit MIRROR_ON 1
edit: save
<< MT5867 >># reset
UART_115200
AC_ON
9TH
MIU0_DQS-OK
BIST0-OK
BAP=1
BAP=1
CusConfig
BAP=1
BAP=1
ree_opt=0000007B
BAP=1
Auth reeloader...
BAP=1
BAP=1
Auth CKB...
Decrypt CKB...
ns_uboot_boot
INFO: R1 0
INFO: R2 0
INFO: R3 0
ree_entry
U[AT][MB][start ub][590]
eMMC 7.28 GB
CID
0x008A66F4
0x73810652
0x34465447
0x38000115
CRC Check OPEN: 1
WOW_GPIO_NUM = 0
WOBT_GPIO_NUM = 255
BTW = FF
USB = FF
VAD = FF
0x8701
Es que no existe, y el comando help en MediaTek no muestra información al respecto.
Los procesadores MediaTek y MStar son similares, al igual que el firmware por script, pero sus comandos difieren.
¿Podrías decirme qué tal funciona este procesador? MSD3663LSA
¿Están disponibles en su zona? Me interesaría mucho la opción de interrumpir el volcado de firmware de 8 MB fusionado por el programador y crear un archivo merge.bin, que luego se pueda flashear a través del menú de firmware integrado en la interfaz del televisor.
Y, por supuesto, la posibilidad de seleccionar un panel predeterminado para que este valor se conserve tras un reinicio. Esta sencilla placa admite una gran cantidad de paneles, pero si reinicias el televisor, la configuración se pierde.
Ejemplo de firmware oficial.
  • MERGE .zip
    3.9 MB · Visitas: 29
No lo sé, tienes que ver sus características en la hoja de datos, si es que la hay.
No, en mi zona solo venden cocos y mojitos. 😄
Con interrumpir, supongo que te refieres a realizar un volcado o respaldo de 8 GB (capacidad de la e-MMC), no 8 MB.
Sí se puede pero me imagino que debe haber limitaciones.
Hasta donde tengo entendido, el sistema MStar solo puede procesar archivos de hasta 150 MB, los que son mayores son comprimidos y separados.
Para esto se usan las instrucciones sparse_write o mmc unlzo.cont (dependiendo del tipo de compresión) y esto le indica al sistema que debe unirlas.
No sé si pueda procesar directamente archivos mayores como system, data, o userdata, que descomprimidos pueden ser superiores a 2 GB.
Es por eso que un firmware tiene un tamaño menor a 4 GB (menor al límite del FAT32), pero cuando se desempaca puede superar los 8 GB.
Como ejemplo: un firmware compilado puede ser de 600 MB y al desempacarlo obtener un total de archivos de ocupan más de 2 GB.
Cuando realizas un volcado estás obteniendo las particiones descomprimidas, y algunas pueden ser muy grandes, por eso en el firmware van comprimidas en partes no superiores a 150 MB.
Sería más conveniente actualizar solo la partición modificada que todo el firmware, es lo que siempre he sugerido, o sea, una actualización parcial.
¡Caramba, siempre pensé que era tequila y sombrero!
Pedí suerte, pensé que tal vez tú habías tenido una experiencia similar.
Me refería específicamente a 8 megabytes. Los televisores convencionales suelen tener un archivo de firmware de 4 megabytes, pero la memoria USB es de 8 megabytes. Si descargas el firmware del televisor usando un programador, tendrá un tamaño de 8 megabytes, pero en un formato que el televisor no reconoce; es decir, no podrás instalarlo como un archivo de 4 megabytes a través del menú de servicio del televisor. Sería interesante contar con una utilidad que pudiera convertir 8 megabytes en 4.
En cuanto a flashear solo una partición, no pude flashear tu archivo la primera vez y hacer funcionar el televisor. Mañana haré una prueba y te cuento.
Analicé el archivo MERGE.bin que subiste y el contenido es de un firmware MStar convencional (No Smart).
El firmware que se distribuye es exactamente igual al que se obtiene del respaldo, pero sin lo que se conoce como bloque de caché, que viene siendo el espacio libre de la memoria SPI Flash.
Entonces tienes un mal concepto con este tipo de firmware, porque el respaldo sí se puede instalar desde una memoria USB, pero se requiere saber el nombre del firmware, que en este caso es "MERGE.bin".
Cuando se distribuye un firmware no contiene el bloque de caché, por eso es de menor tamaño que el respaldo.
Desde fábrica también pueden grabar una clave HDCP que va en el bloque de caché, y una actualización por USB no la borra porque no toca ese bloque.
Para no salirse del tema y como este tipo de firmware ya se ha tratado, puedes mirar este tema y usar la última versión de la aplicación.
Hola compañeros, tengo una Tv JVC Si50ur con placa 40-ms22e1-maa2hg con sistema roku,
IMG_1215.JPG diagnostiqué un corto en esta board por lo cual me toco conseguir otra de una philips que maneja la misma board, al colocarla funciona bien solo tiene el detalle de imagen duplicadaimage-1762563115708.jpg
ya intente acceder al menu de servicio con la combinacion 5 HOME + 2 Retroceder + 2 Avanzar + 1 Play y no entra, tambien intente otras combinacion que he visto por internet, la unica que pudo funcionar es 5 HOME + 4 Retroceder + 1 Play y entra a la app de roku tunning app. tengo esta info de ahi
Mi duda es por qué no me deja entrar al menu de servicio para modificar el project id. esta es la info del panel y tcon que tengo, segun chat gpt podria ser el project id #24
Creen que pueda cambiar el project id desde la consola? tengo acceso al UART. a alguien le ha pasado?
Ya intenté acceder al menú de servicio con la combinación 5 HOME + 2 Retroceder + 2 Avanzar + 1 Play y no entra.
Esa es la combinación de Factory Menu donde se puede cambiar el Project ID.
Tal vez te equivocaste de teclas, ya que muchos usan las del pad violeta y deben ser las laterales de Play/Pause.
En la imagen adjunta se muestran las teclas con la secuencia.
¿Creen que pueda cambiar el Project ID desde la consola?
No lo creo posible, yo siempre lo he hecho desde el Factory Menu.
    24.3 KB · Visitas: 26
Ok veo una tecla extra en la imagen, mañana lo probaré a ver qué resultado le da.. muchas gracias
No me funcionó esa combinación de teclas, hay alguna otra combinación o si puede que tenga deshabilitado el factory menu?
Estoy usando el control original de la tv, es IR
hola compañeros doy una pequeña actualizacion de lo que hice con el caso del project id de roku tv, al final opte por cambiar la nand de la tarjeta original(JVC 50") a la tarjeta de remplazo(Philips 58") para ver si esto corregia el problema de imagen,
lamentablemente no funciono. lo que obtengo de log en el uart es este
lo subo para que quede evidencia de estos casos con projet id. ya ahora si se me terminaron las ideas para resolverlo, lo que se me hace extraño es que no funciona el código del menú factory :/
¿Puedes tener acceso a depuración, o sea, puedes enviar comandos?
Es que si el UART está deshabilitado solo recibirás información pero no enviar comandos.
Si puedes enviar comandos realiza un respaldo de la NAND que tiene el projectID correcto.
Por el modelo MS22E1 se deduce que la plataforma es MStar y funcionaría con Nugget que es para comandos NAND.
Si el volcado resultante tiene la estructura básica, podrás usar MStar Dump Extractor y analizar las particiones EXT4 para buscar el valor del ProjectID.
Si es que lo encuentras, reemplaza la partición que lo contiene con EFI_Xer Tool, ya que es más fácil por ser de reemplazo directo.
Esto no es garantía de que funcione, es experimental para probar.
Al parecer no me deja enviar comandos, intento con mstar-nugget access y no hace nada. probablemente tiene el uart deshabilitado.
Me gustaria experimentar ya que nunca me había tocado un caso como este.
Me imaginé, ya que cuando se muestra un Device ID en el log, es porque el UART está protegido con Password.
Antes se podía obtener porque la empresa tenía una página para proporcionar el Password en base al Device ID, pero ya no está disponible ni por correo electrónico.
La otra manera es leer la NAND con programador, y supongo que la NAND va emparejada con el Device ID del procesador, por eso no funcionó el reemplazo.
Lo mismo sucede con las e-MMC en algunas placas LG y otras, si grabas un respaldo el TV se queda en el logo, se necesita una e-MMC nueva, extraer la clave del RPMB y grabarlo, ya que esta zona es OTP.
si pense en lo mismo, intente hacer el dump con la rt809f en los test point que indica la boardimage-1762732342059.jpg
pero me quede en eso. no tengo el adaptador isp y me dio flojera hacer uno.
Aparte que pregunte a chatgpt si era posible y me hablo de los estados de la memoria y colocar resistencias y se me hizo tedioso por eso opte con remplazar la nand a ver si resolvía
alguna recomendación para intentar hacer el dump?
Ok seguiré buscando información para hacerlo desde factory menu, ya regresé la nand original de esa placa.. buscaré mas info por internet, el modelo es 58pfl5666/f8 por si alguien tiene el service manual.
Lo que probaré es conseguir un control Roku universal y programarlo con Philips para ver si así si me entra con el código.
Si encuentro solución lo estaré posteando, muchas gracias 👏🏻.
Actualización rapida 😂, logre entrar al menú pero aún no he podido configurar bien el project Id
Comparto el procedimiento por si alguien requiere hacerlo
Con la siguiente combinación se entra al menú
5 Home + 4 FF + 1 Play
Luego entras donde dice Load TCL Mfg App y ahí es donde te carga el factory menu
Ahora aquí, me fui al apartado del project ID y me deja mover el valor y veo el modelo del panel al cambiar, coloco el que debe de llevar (CV500u2-t01) pero no veo que haga cambio de la imagen o tal vez no lo estoy configurando como tal
Me gustaría si me podrían ayudar en esta parte, he visto en otros tutoriales que hay por Youtube que comentan que hay que hacerle un reset al nvm pero tengo miedo que quede sin Control remoto o algo por el estilo jejeje
Alguna recomendación?
